Question about Springfield Measuring Tools & Sensors
Remote sensor Remore sensor reads LL.L That is what shows on base statoneadout also.
Instant dig read thermometer shows LL and I can't get a reading
LL means that the sensor is below the rated temp It could be a bad sensor.
Apr 11, 2017 | Home
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
I have Losed the remote for my XD Box. Where can I get another remore for the box
Roku sells a replacement remote for their units on the Accessories page: http://shop.roku.com/accessories-all . The remote that works with the XD is ~$15 + tax/shipping&handling.
I hope this helps.
Apr 01, 2014 | Televison & Video
Ir sensor may be defective
It may be a defective remore control,They are infrared light to test one get a digital camera aim the remote directly at the cameras lens push remotes buttons you should see the pulses on the cameras lcd screen,the human eye can't see IR light but the cameras sensor can,quick test ,
Mar 06, 2014 | Vizio M550SL - 55" Class 54.64" viewable...
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
Just put new batteries in remote sensor but now cannot get it to transmit to base station
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Or look on eBay, usually much cheaper if available.
May 27, 2011 | Audio Players & Recorders
Gas fire place does not turn on with the remote but turns on only with the switch at the lower left corner. It seems to be a direct vent type gas fireplace. I wonder if the damper is not opening and the...
you have no damper, it was removed to put gas unit in. chcek batteries in remore and in RECEIVER, receiver is usually forgot about it is insdie the bottom door more than likely, the fan only comes on when unit is up to temp, it has a heat sensor on bottom of unit, check wires on a gas valve for remore receiver as well, usually go on top and bottom screws
Jan 29, 2010 | Desa International Wall/Window Air...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Measuring Tools & Sensors Logo
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
