Question about Panasonic SC-HT70 System
Suroupd system wont play thru tv - Panasonic SC-HT70 System
No sound thru my Bose system attached to my tv when I try to play my music thru my apple tv from itunes
What audio connector do you have running from the TV to Bose system? What input options are there on the Bose system?
Mar 16, 2014 | Zynga iPhone Apps
Hi. i cant get the menu screen on my panasonic sc-pt90. and it wont play thru my tv
First and most important thing is - Is it connected to your TV? If it is you might try a different lead. You haven't said if this is a reinstall or a new install. If it is a new install, you should take it back to where you bought it. If it is a Reinstall, then the most likely problems are :- cable or connectors. if a cable replacement doesn't fix it, you might try pluging it into a different connector on your TV. Also make sure you are trying to view it on the correct channel of your TV. Hope this helps.
Nov 28, 2011 | Panasonic Home Theater System System
Can i get my sound to play thru tv and not just my dvd
i have a colby tv-dvd combo, i can hear sound when i play dvd but not when it is in tv mode. i think my daughter hit button on remote ?
Dec 28, 2009 | Coby DVD938 Theater System
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
Sound problems/ receiver
NO., it cant be played thru both when it is in cd/dvd mode because from manufacturing it vl be like that. it cant give its sound to other when in cd/dvd. how am telling is i have YAMAHA yht-165. when i use dvd mode.. the sound wont get thru its output. only works when its in other modes like tuner, md-r, tv, aux.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jan 26, 2009 | Samsung HT-DS610 System
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Nov 06, 2007 | Durabrand HT-3915 System
Panasonic SC-HT70 System Logo
24 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
