Question about Ultrak 330 Stopwatch
Turning off stopwatch
Can I ever turn off the stopwatch; or must it operate continuously?
Can I turn the beep off on the stopwatch?
Generally most of the new stopwatches have a mute function that allows you to turn off its beeps but not in all of them. You can visit http://www.johnisfit.com/2008/10/23/sportline-240-stopwatch-how-to-stop-the-alarm/ to see exactly how to do it on your stopwatch.
Aug 02, 2012 | Exercise & Fitness
Need manual for rolex daytona men's watch
Hello
These are the things you might need about the watch.
1. Turn the crown clockwise while it is in position 2 to manually wind the watch.It will stop if it has not been worn out or put in a watch winder for roughly two days.
2. Pull the crown out one notch to position 3 to change the time.Turn the crown clockwise to move the minute hand.
3. Push the crown back into the watch while turning it clockwise to return the crown to position 1.The crown should be tight to ensure the watch case is waterproof.
4. Operate the stopwatch and chronograph function by pressing the button located above the crown on the 3 o clock side of the watch.Stop the stopwatch by pressing the button again,Reset the stopwatch by pressing the button below the crown.
BEST OF LUCK
Jul 13, 2010 | Rolex SS/18kt Daytona
How could I remove alarm on junso 7064 stopwatch? or where I find manual for this stopwatch? thanks
Did you ever find a solution to turning the alarm off this stopwatch.I have the same problem.!!!
May 10, 2010 | Jwin Watches
I need the operation manual for the 228 stopwatch
You can get the manual on link below.
http://www.sportline.com/manuals/228.pdf
Please rate 4 thumbs for the free answer
Mar 01, 2010 | Sportline Stopwatch
How i can pause and continue a timer in visual c# i am making a stopwatch ........ pleas help
I would suggest you use the stopwatch class! Here is a nice example.
If this helped please help me and vote kindly!
Jun 12, 2009 | Microsoft ASP.NET Programming with MS...
Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Mar 25, 2009 | Invicta 3209 Lupah Diver Watch
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Alarm on 2006 sportlines stop watch
I'm not sure which stopwatch you have, but if it's a 3 button one with Split on the left, Mode in the middle and Start/Stop on the right, try pressing the left and right button at the same time. Hopefully, this will turn it off. The little 'sound waves' should disappear. Good luck.
Dave.
Jer. 29:11
Oct 14, 2008 | Sportline Stopwatch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Ultrak 330 Stopwatch Logo
32 people viewed this question
Top Ultrak Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Ultrak Exercise and Fitnes Expert? Answer questions, earn points and help others
