Question about Braun 8585 Electric Shaver
Open Braun razor casing - Braun 8585 Electric Shaver
5 Suggested Answers
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
SOURCE: how do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Posted on May 25, 2009
brector3
  • 1610 Answers
SOURCE: How do you open a Braun 360 razor?
Remove the 'cap' on the bottom that surrounds the cord inlet by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will pull away revealing 4 screws. Remove the screws to seperate the front and back of the shaver and access the insides.
If needed, you will find parts for this model at shaveroutlet.com
Posted on Sep 10, 2010
brector3
  • 1610 Answers
SOURCE: I have a braun 5614 razor bought in usa many years
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Posted on Sep 12, 2010
How to fix braun series 5 trimmer
Search Results
    Repair your Braun Cruzer 3 Trimmer MacGyver style in 6 ...
    ? 6:36
    https://www.youtube.com/watch?v=ZH1NRbDidRM
    Jul 30, 2012 - Uploaded by Ed el Vise
    My Braun Cruzer 3 Trimmer suddenly stopped working. ... I have replaced screens now on 5 different cell ...
    Braun series 3 razor fix - YouTube
    ? 3:00
    https://www.youtube.com/watch?v=mSdJu_iaEjs
    Oct 16, 2014 - Uploaded by mruberg1
    How to fix the Braun series 3 razor, after the trimmerattachment, falls off, due to sonic weld failures ...
    Braun Series 3 disassembling trymer rozbieranie - YouTube
Jan 18, 2016 | Braun Health & Beauty
Braun new zealand
If it is not in the user manual, you should not dismantle the Brown razors. I know they are very difficult to open and a pain to reassemble. They can easily be damaged when you try to " repair" these shavers. Just send it back to Braun, or your shop. In Europe we have 2 years of warranty. If the warranty is over, please buy a new one.
Jun 29, 2014 | Braun Pulsonic Rechargeable Cordless Men's...
Problem disassembling Braun 4700 series razor
This video should help you in your quest to disassemble your electric shaver
Jan 24, 2014 | Braun 4775 Electric Shaver
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
Sep 12, 2010 | Braun Health & Beauty
Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Jun 12, 2010 | Braun 360° Complete 8985 Electric Shaver
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
Feb 20, 2010 | Braun Health & Beauty
The power on switch on my Braun 7526 does no stay in its upper most position. Something is broken inside. How can I open the cage to see inside
open the head of the razor and look for screws, also look at the bottom. once they are removed varefully unsnap the casing.
Aug 19, 2009 | Braun Health & Beauty
How do I open the case to change the battery?
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Repairing electric razor
Questions,
What can be done to eliminate self-starting; slide switches which have become exremely sensitive to the touch and often times turn on when set down after use.
Slide switch covers no longer return to full "off" position. Ive had to use scotch tape to prevent them powering on when placed in suitcase, for example. Is this problem characteristic of Braun razors?
Can a nonprofessional open up casing to administer a very thorough cleaning? And where would one get an instructional schematic? Can one be obtained from Braun?
Thx!! Vince
May 12, 2008 | Health & Beauty
Braun 8585 Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
