Question about Mr. Coffee BVMCPSTX91
I don't understand descaling instructions on magimix L'Espresso program automatic coffee machine
It describes an automatic descaling program taking about 30 min, but it doesn't work accordingly
4 Suggested Answers
SOURCE: My Mr Coffee espresso machine
On my machine, the vent from the heating element to the steamer control was clogged. I am a trained professional, do this at your own risk! I did the following because I tried everything else and I knew that the unit was clogged at the aperature from the hot water element tank. Try to unclog it another way before doing this!
1. Unplug from the wall outlet!!! (don't skip this or you might die!)
2. Remove accessories, water holder, bottom tray, etc.
3. Remove the rubber feet and unscrew all of the screws you can find. There are some hard to find screws but it is possible to remove them all with the right screwdrivers. I broke the last screw stud thing on mine because I couldn't find the right tool for that last screw. Once I got it apart, I figured out how to do it. I cant remember now though. Just break it if you want. There are plenty of other screws holding this thing together.
4. Remove the top.
5. Follow the smallest tube to the heating element (looks like a tiny hot water heater).
6. Unbolt the tube fitting at the heating element. You may loosen the other couplers, but dont completely unscrew them, and DO NOT TUG on the small plastic tube. Once you unscrew the brass fitting, take a flashlight and look in the hole that leads into the heating tank. If yours is like mine, it will be clogged with white goo. My goo was from hard water. Take a pipe cleaner and ram it through the goo. Try to get as much goo out as you can, but it is ok to get some down into the tank.
7. Put everything back together carefully. You might want to replace the small O ring at the fitting if it is worn out.
8. Run vinegar through the system, or CLR or some other solvent that can break down the hard water residue. Plug in the unit and flush the system with cleaner but make sure to get it all out. Run alot of clean water through it.
** you might be able to just run CLR or Vinegar or some other cleaner through the system, without disassembly. I am not an expert in these things, please find out what is safe to use before trying it. I am not responsible if you get poisoned!
Hope this helps some!
Posted on Feb 01, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: I bought a Mr. Coffee Espresso Machine at a garage
HELLO MARY , HERE'S A LINK TO THE MANUAL FOR YOUR EXPRESSO MACHINE JUST CLICK ON THE ECM91 AND IT'LL BRING UP THE MANUAL FOR YOUR MACHINE.
http://www.mrcoffee.com/InstructionManuals.aspx
Posted on Apr 05, 2009
SOURCE: New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Posted on May 20, 2009
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
Hot water tap no longer works. Cleaned out deposits and it still only drips out. What needs to be done. I fear the boiler is corroded or the tap is blocked with calcium despite the water filtering system....
Because the hot water spout is controlled by gravity, it is partially clogged, Here is a little story and see if this helps,Let me know
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 23, 2011 | Bunn VLPF Coffee Maker
How do you descale the machine,as we have no manual
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to clean coffee machine properly? i was given one and want to ensure that it is save from "everything" so i can start using it.
Jun 09, 2011 | Coffee Makers & Espresso Machines
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
My magimix coffee nespresso machine has just been descaled but still has flashing lights - how can i stop the flasing lights
Thanks Tish3030! By far the most helpful answer! The manual did not help at all. Besides, I can get the manual anywhere on the internet. :p Removing the tray worked! Genius!
May 31, 2010 | Magimix L'Expresso Espresso Machine
Mr. Coffee BVMCPSTX91 Logo
20 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
