Question about Optoma EW1610 DLP Projector
Optoma ew1610 fan locked
Fan locked
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Optoma H27 fan failure
hi Sir,
why you not go to ebay for help?
it has two fans, one is 70*20mm AXIAL Fan, another is 50*20mm blower fan, which one goes bad?
find out and just replace it, it will be ok.
Jul 30, 2014 | Optoma Office Equipment & Supplies
LG DLP projector fan lock problem
hi, i have fan locked problem on lg projector.
Apr 23, 2012 | Optoma HD65 DLP Projector
Optoma HD65 Fan Replacement?
im after a fan for the optoma hd65 projector its a sunon 12v 3.0w 20x60x60
Mar 14, 2012 | Optoma HD65 DLP Projector
HELP!>After replacing a new bulb, I turn it on and 3 seconds later it said Fan Locked and turns off. Any ideas? Thanks
Hi sir
firstly try to clear the induction of color wheel,
if it still happen same hint, perhaps the fan was failure.
hope i can help you.
regards,
Jack
wanminjun@gmail.com
professional whole saler and retailer for below products:
most of brand projector spare parts: lens, color wheel, bulb, mother board, etc. match for Benq,sharp, optoma, samung,dell, etc.
HP server, router, switch,
computer motehr board, hard disk. DELL, IBM, ASCUS, Hp etc
Nov 10, 2011 | Optoma HD65 DLP Projector
Warning: fan locked contact service center for
di pasang kipas baru tapi masih bertuliskan warning fan locked terus mati..projektornya
Jun 23, 2011 | Optoma HD65 DLP Projector
Hey my optoma hd65 bulb blew so i replaced it and when i powered it back up i received the fan lock error
the lamp probably blew because the fan stopped. if the lamp can't cool down, it blows. you'll have to find out which fan and replace it.
Nov 07, 2009 | Optoma HD65 DLP Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma EW1610 DLP Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
