Question about Canon WMV1 Microphone
Canon wmv1 dead
Every battery will not work, even new batteries. keeps giving a red light and won't light up blue to connect to receiver.
SOURCE: CANON POWERSHOT A530 LOW BATTERY READING
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
  • 4090 Answers
SOURCE: reset ink counter for canon mp630
The cartridges have small chips on the lower face Once it registers empty that casette will not woek again. Many of the replacement cartridges that are not genuine have this chip missing. You can transfer the old chip to the new vcartroidge ( if its not a genuine with a replacement reset chip. I think you can by a chip resetter for this model. do a web search fot your model they are por etty cheap to buy
Posted on Jul 28, 2009
Rammsteins
  • 300 Answers
SOURCE: Powershot SX100 low battery symbol with new batteries
Hi!
If you're sure that the batteries are full, then the power board has to be changed. It's the first board under back cover, with the buttons on the other side of it. Contact your local Canon service center. If they ask very much, you can contact me toms.safranovs@gmail.com and I can give you a price - I have access to new Canon parts.
Tom
  • 1705 Answers
SOURCE: Canon PowerShot SX10 keeps telling me that I need
May I suggest going to the Canon website, follow menu options Support and Downloads and look for a firmware upgrade.
Posted on Mar 21, 2010
SOURCE: My canon SX110 IS camera
I had the same problem with new batteries reporting as "low" and instant shut-off. After I found that it would stay on when plugged into USB, I suspected a firmware bug in the camera (I am a computer engineer). So I thought "how can I fool it?" I then found that it would stay on if you power it up with the rotary dial BETWEEN the video and manual ("M") setting -- in the "illegal" position. The after it's on, every mode works!
--Dan S.
Ithaca, NY
Posted on Oct 29, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
Only lights up red and does'nt work
The red light indicates a dead battery. Test the battery with a volt meter, to make certain you do not have a bad battery. Even if the battery was "new", it still might be bad. If that does not resolve the problem, contact Shure to have receiver repaired.
Oct 04, 2012 | Shure P4R Microphone
Hi my Pavilion dv3 refuses to start unless I connect it with the adapter. Even then, the battery won't charge and it will stay "55% Plugged in, Not charging". I figured that my battery is...
There is only one reason why this is so because the battery is dead finally. There is no other possible cause to this. The battery lights keep blinking because the battery does not hold power anymore.
hope this solution has been helpful?
Jun 20, 2011 | Computers & Internet
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
I just received the canon EF 100-400m lens for Christmas. I was using it on my canon EOS 20D and it just shut down. I thought I had a dead battery but even after charging the batery, I couldn't get my...
I've had this happen right in the middle of a shoot, what I found first was that I had pushed the lens release button and the lens moved ever so slightly but enough to mess up the connections and everything went dead. Another thing is not having the battery at a full charged but if it's not coming on at all I'd be checking the battery door make sure it's latched securely. Next make sure the Card is down and locked in the seat and the card door is closed and locked. Clean the contacts on the camera body and lens (this generally gives an error 99 though) with a red soft pencil eraser keep the lens as vertical as possible when lightly cleaning (polishing) the lens contacts. Keep the lens cavity pointing down as much as possible while cleaning (polishing) the body contacts another thing and my 20D is coming due for this as well is a back up battery this replacement is found on page 35 of your manual Oops not manual here is a diagram
Diagram
Here is where to look and what to do diagram
Diagram
This should put you back into the photography again Cheers Have fun with that great lens
Jan 17, 2011 | Canon EOS-20D Body only Digital Camera
Hi!
Tom
Jul 28, 2009 | Canon PowerShot SX100 IS Digital Camera
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Canon WMV1 Microphone Logo
Top Canon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Canon Audio Player and Recorder Expert? Answer questions, earn points and help others
