Question about Roland Music
Need the steps to setting up a boss ds 330 with a roland pk 5
How do i set up the device to record
Your best bet is to read the manual. Here is a link to it on Roland's web site MICRO BR Manuals Support Roland
Feb 08, 2015 | Roland Boss Micro BR Micro br 4 Track...
How do I connect my Boss CE-5 pedal for stereo?
Quite simply connect each output to its own guitar amp or use two mono or one stereo DI box and connect to stereo PA.
Sep 25, 2014 | Roland Boss CE-5 Chorus Ensemble CE5...
Volume knob is broen
The obvious answer is to have it repaired. Sometimes the parts can be hard to find but either DigiKey.com would have the part or you can go to Roland/Boss and order the part. If the knob itself was smashed, the pot also is likely damaged. $5 of parts should fix it up. If you are adept at electronic repair it should be an easy fix.
Jun 17, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Parts
Most parts are standard parts available from DigiKey.com or Mouser.com. You need to be electronic savvy to choose the right ones.
May 04, 2010 | Roland Boss Ch-1 Super Chorus
I don't know how to set my roland u-20 for using a hold pedal "Kurzweil". My hold pedal is new, but i can´t make it work.
The Roland requires a NORMALLY CLOSED contact and that usually cannot be changed.
You will need to reverse the contacts in your pedal to meet that requirement.
OFTEN the pedals have BOTH contacts and you just have to unsolder and move the wire to the opposite contact. This is a common problem
Oct 29, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Music Logo
14 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
