Question about SewShop.com Singer Model 6233 Instruction Manual
Getting singer model 6233 out of reverse - SewShop.com Singer Model 6233 Instruction Manual
Feed dogs are not advancing material
check the position of the forward / reverse lever or knob
this indicates that the selection is in the middle
check for a broken drive belt in the head of the machine not driving the bobbin shaft
Nov 08, 2015 | SewShop.com Singer Model 513 Instruction...
Can I get a manual for singer model 776 sewing machine?
try going to google and put in singer sewing machine and model number and it should pull up some sites
Jul 25, 2014 | SewShop.com Singer Model 776 Instruction...
What is wrong with my singer sewing machine model 6233?
That may be a relay inside going bad. Sounds
like a small part heats up too much, then it
needs to cool down to function again.
May 31, 2014 | SewShop.com Singer Model 6233 Instruction...
Feed dogs where is switch
You should post this in the sewing machine section. It is posted in the vacuum section
Jan 25, 2014 | SewShop.com Singer Model 6233 Instruction...
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
My Singer Sewing machine (model 6215) is now only sewing in reverse. After pressing the backstitch button, the button seemed to stick in the backstitch position. I was finally able to pull the button out...
It's stuck inside. Open it up so you can see inside the bottom, look for the feed dog mechanism and you'll find where length of step is varied, this is where the reversing takes place too. Tapping gently and oiling will free it up.
lp
Dec 29, 2010 | Vacuums
SewShop.com Singer Model 6233 Instruction Manual Logo
57 people viewed this question
Top SewShop.com Vacuums Experts
Ron Lake
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
