Question about Advent 4211c Notebook
How to change advent notebook boot device order
When I power on my Advent Tacto the Advent logo comes up and then just sits there. I have tried break on power up but that makes no difference.
Removing the hard drive will not boot to the BIOS. Try pressing F2 when your laptop is booting. Change the boot order to your hard drive.
Sep 18, 2016 | Advent Computers & Internet
I have and advent 4211-b says ntldr files are missing i cant get on anything i want to reinstall vista but i cant get it to boot from usb please help
If you enter F8 just before the boot process you may be able to use the restore function otherwise enter the bios as you power on and set USB as 1st boot device.
Feb 24, 2014 | Advent 4211c Notebook
What is boot device?
Boot Device pertains to your hard disk that is installed in your laptop where the Operating System is installed in order for it to run. If an operating system is not installed, it will require the installation CD/DVD disc where it will boot alternately until its installed.
There are certain issues that the system does not boot on the hard whenever the settings is primarily set to boot to a USB or CD/DVD device initially wherein either a USB drive is attached or a CD/DVD disc is inserted.
Aug 18, 2010 | Advent Netbook
An error occured while attempting to read the boot configuration data The above appears on boot-up, how can I make a bootable usb stick in order to copy XP onto it to try and use "repair" to rix the...
U will have to extract the Windows CD to a file folder on your pc. Run Nlite to make a bootable file to load to ur flash drive. Then u will need to set ur bios to boot from USB device. Mainly needing the Boot.INI
Aug 16, 2010 | Advent 4211c Notebook
I need to change boot device how can i change it?
To change the boot order of devices.
Go to the BIOS configuration and under one of the sections there will be a boot up section where you can change the order of boot up devices.
Apr 04, 2010 | Samsung V20 XVC 2400 Notebook
Computer will not start.
Well it seems that there may have been wither a compatibility problem or a .dll file has been erased. I suggest removing the recently added device, or any new hardware added see if that changes anything or you may have to reinstall Windows.
Feb 07, 2010 | Advent 4211c Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Reboot an advent notebook to original settings
the computer shoulda came with a disk and that would be your operating system disk so put it in, then start your computer and if it doesnt boot to the disk, then hit F2 and change the boot options and make it boot from the disk and so when it does boot, then thats when u can reinstall windows back to factory settings but i dunno about advent notebooks. in HP tho, u can do it from the start menu cuz the reinstall settings are already on your computer so ya dont need the disk
Dec 27, 2009 | Advent Netbook
I am having hp pavilion dv2000 notebook pc.
try to go into BIOS by pressing F2 or Del while booting...
then change boot device order as 1st boot device as Hard disk
Dec 11, 2008 | HP Pavilion dv1000 Notebook
Advent 4211c Notebook Logo
18 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
