Question about ATT - Avaya - Lucent AT&T Avaya Lucent 4 Line Phone 954
Reset after power interruption
I unplugged the phone to switch outlets. When I plugged it back in, it rings continuously and the screens flashes continuously.
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    0xc18a0001 failure
    You could try a power reset of the printer.
    Press ON button to turn off printer
    Unplug the power cord from the back of the printer
    Remove all of the ink cartridges
    Wait 3 minutes
    Plug the power cord back into the printer
    Press the ON button to turn on the printer
    Install back all of the cartridges
    If this does not work, you could try a hardware reset.
    1) Press and hold LEFT ARROW and then press SETUP
    Release both buttons
    2) Press OK
    3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
    4) Press OK
    5) LCD reads Hardware Failure Status: Clear, Press OK to clear
    6) Press OK, LCD now reads Cleared, Press Cancel to continue.
    7) Press & release CANCEL until the Welcome or Ink System
    Failure screen appears on LCD
    8) DO NOT PRINT AT THIS STAGE
    9) Use POWER button to turn OFF printer
    10) Unplug power cord from electrical outlet and from back of printer
    11) Wait 1 minute. plug power cord back into outlet first then back into the printer
    12)Turn on the printer, Press OK
    The printer will start to initiate, do not interrupt.
    Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
    Problem with att cordless phone wont ring
    First, check the wirings (power cord and phone cord). Are they properly plugged in to their outlets (power outlet and phone jack, respectively)? Have you tried plugging in another phone? Does it ring? If yes, it could be your phone system, if not, let's try this troubleshooting steps. This is one of the basic troubleshooting steps for cordless phones. Unplug the battery from the phone/s, unplug the power plug from the main base unit. Wait for 10-15 seconds and plug everything back in. First the batteries then the power plug.
    Sep 04, 2011 | AT&T Lands Phones
    Standby light blinks 4 times
    The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
    The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
    If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
    If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
    Try the following steps to check if the issue can be resolved.
    Turn off the television.
    Unplug the television power cord from the electrical outlet.
    Let the television remain without power for 60 seconds.
    Plug the power cord back into the electrical outlet.
    If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    If the issue continues to occur, service may be required.
    Thanks for using Fixya.
    Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    KDF 50E2000 WONT POWER UP POWER LITE BLINKS RED 3 TIMES THANKS
    If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
    May 12, 2011 | Sony KDF-50E2000 50" HDTV
    Error code 0xc18a0201
    Hi.
    The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
    If that does not work try the procedure below:
    "Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys.
    Display should say "Enter Special Key Combo"
    Press and release the "OK" button
    1. Press and release the right arrow button until the display says "System Configuration Menu".
    2. Press and release the "OK" button.
    3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    4. Press and release the "OK" button.
    5. Display should say "Hardware failure status: Clear. Press OK to clear".
    6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
    11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
    NOTE: If the error is still there, or reoccurs replace the unit."
    Procedure from http://www.fixyourownprinter.com
    Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
    Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
    : Check the power cord
    1.
    Turn on the product.
    2.
    Remove the power cord from the back of the product.
    3.
    Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
    If these steps resolved the issue , you do not need to continue troubleshooting.
    If the issue persists , continue to the next solution.
    Turn the product off and then on again
    1.
    Press the Power button ( ) to turn the product off.
    2.
    Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
    3.
    If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
    Plug the product into a wall outlet
    Follow these steps to make sure the product is plugged in correctly.
    1.
    Unplug the power cord from the back of the product.
    2.
    Unplug the power cord from any surge protectors or power strips.
    3.
    Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
    4.
    Plug the power cord into the back of the product.
    5.
    Plug the power cord into the wall outlet.
    6.
    Press the Power button ( ) to turn the product on.
    Solution six: Reset the product
    Follow these steps to reset the printer.
    1.
    2.
    Unplug the power cord from the wall outlet.
    3.
    Wait 10 seconds, and then plug the power cord back into the wall outlet.
    4.
    NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
    5.
    6. Perform a partial reset of the product
    1. Disconnect the power cord from the product.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while reconnecting the power cord.
    4. When the product turns on, release both buttons.
    5. Try printing again.
    IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
    Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
    Xbox power light blinks and freezes xbox
    That flashing green light meens there is a problem with the power to you DVD drive. the power is being interrupted. ie, when you have power the welcome screen will load and when it doesn't it will shut off. you don't have continuos power. For example if you have the power cable unpluged and then plug it in with the power on the xbox will reboot. Check the wires and the port on the motherboard if all is ok you need a new drive.
    Jun 24, 2009 | Microsoft Xbox 360 Console
    Switch will not turn on disposal
    under the sink you will probably find an electrical outlet with the disposal cord plugged in. If so, plug another item into the outlet like a blow dryer to be sure you have power to the outlet. If you have no power the problem is a tripped breaker or a blown fuse. First check all of the plugs in the kitchen area including under the sink to determine if you have a ground fault circuit interrupter outlet. If you do, it may be tripped. If it is tripped simply reset it.
    If you know you have power to the disposal then check to be sure no spoon or other hard object isn't in the disposal preventing it from operating. Use a flash light to check this. If there is no obstruction look on the case of the disposal for a reset button. good luck.
    Jan 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
    Ringer
    Unplug the phone and plug it back in. Really. It just worked for me.
    Dec 12, 2007 | GE 28112EE2 Cordless Phone
    ATT - Avaya - Lucent AT&T Avaya Lucent 4 Line Phone 954 Logo
    20 people viewed this question
    Top ATT - Avaya - Lucent Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you an ATT - Avaya - Lucent Lands Phone Expert? Answer questions, earn points and help others
