Question about AEG Cooktops
Wasmachine aeg error E6A - AEG Cooktops
I have an AEG induction hob which is 10m old. There has appeared a scorch mark in it that looks like it's from a pan. There is no burn or residue to clean off but it looks like the glass is damaged. Has...
not sure as to what you can do , if it did get too hot, maybe wrong pan, but could also be wrong temp in unit, only way to find out is to try and use warrenty
Jan 22, 2015 | AEG Cooktops
E 3 error what does this indicate?
Error Code: E3Reason: The voltage is higher (140V-160V)for 3 secondsSource: Induction Cooker Error Codes Explained
Aug 20, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
I get E9 error from my induction cooker
If its a Rangemaster induction cooker, I had the same problem and its caused by a Loose or faulty PT sensor under the glass, you need a qualified engineer to rectify it.
Feb 08, 2011 | AEG 23 in. 68001KF-N Electric Cooktop
Using a Berlin induction electric stovetop - I keep getting the error E1 and my landlord didn't leave me a user manual. Does anyone know what this means?
Dear friend,
im sure if you go to the AEG website & type your modle # etc, you would most probably find a downloadable user manual for that. Give it a go.
Cheers
Jim.S.
Dec 27, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
We got an E3 error message on induction cooktop(induction hob), AEG 88101 K-MN, which followed a popping sound. What could it be? We checked the braker and fusers.
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Cooktops Logo
126 people viewed this question
Top AEG Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
