Question about Texas Instruments TI-82 Calculator
Dim mismatch when i type in cos x under y= and push graph i get dim mismatch
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features..
Posted on Jan 23, 2010
I get a ERR: DIM MISMATCH when I try to use graph an inequality using the inequalz app
Your TI-84 Plus displays the ERR:DIM MISMATCH error if you are trying to perform an operation that references one or more lists or matrices whose dimensions do not match.
For example, multiplying L1*L2, where L1={1,2,3,4,5} and L2={1,2} produces an ERR:DIM MISMATCH error because the number of elements in L1 and L2 do not match
Nov 29, 2012 | Texas Instruments TI-84 Plus Silver...
How do I get rid of the ERR:DIM MISMATCH message?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jun 08, 2012 | Texas Instruments TI-84 Plus Calculator
When trying to write simple graph lie Y=x+3 i get err: DIM MISMATCH QUIT
Dimension mismatch error occurs when arguments are not with same dimensions. Two or more arguments must be of the same dimension. For example, [1,2]+[1,2,3] is a dimension mismatch because the matrices contain a different number of elements. By the way, it it very easy to resolving your problem with graphing linear function. See captured image
Sep 22, 2011 | Texas Instruments TI-82 Calculator
TI-84 Plus Linear Regression (ax+b) ERR:DIM MISMATCH
Some old configuration settings, or old variables are spoiling your fun. Clear the RAM and start again.
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 plus problem
Reset the calculator RAM and retry. Some old configuration settings are giving you the error.
Hope it helps.
Graphing sine
Sure.
Press Y=. Type in ( 1 / 2 ) * cos( X ) ENTER
Press GRAPH to see the graph.
If the graph isn't too clear, press WINDOW and change Ymin to -2 and Ymax to 2, then press GRAPH again.
Note: for -2, be sure to use the (-) key next to the decimal point instead of the - between the multiply and the add.
Mar 12, 2009 | Texas Instruments TI-84 Plus Calculator
Dim Mismatch
That is because you don't have the right amount of points. Either delete one point or add another point. Then try to graph it.
Jan 10, 2009 | Texas Instruments TI-84 Plus Silver...
Getting a DIM:MISMATCH when i want to draw a graphic, tmmrw exam
Dec 07, 2008 | Texas Instruments TI-83 Plus Calculator
Dim Mismatch
Hit 2nd then the Y= button and you'll get to the stat plots. make sure they are all turned off, sometimes random programs (ie. games) will turn on stat plots and screw up your other programs and graphs.
Sep 25, 2008 | Texas Instruments TI-84 Plus Silver...
Dim mismatch error
Hello matilda. The Y is your vertical & X is horzonial. With TI-83PULSE you should aquire a 'V' on the graph with point of V at center cross with Y=X^2. You can't aquire a Y=Y1+X^2
May 18, 2008 | Texas Instruments TI-82 Calculator
Texas Instruments TI-82 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
