Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Toshiba laptop not connecting to optoma - Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma EZ Pro does not connect to laptop. Tried Control Panel / connect to laptop / dual display, but computer will not recognise projector.
reload software and reboot entire system after make sure Optoma power is turned on before turning on computer
Jul 21, 2010 | Samsung Computers & Internet
How to connect the Optoma Pico PK-101 DLP to a laptop
You have to buy a 17€ converter.... here on my website, is a diagramm on the B chapter that explain a lot.
http://shadar.spacequadrat.de/?p=121#more-121
Here is the link to buy one converter
http://shop.ebay.fr/i.html?_nkw=pc+VGA+to+converter&_sacat=0&defsort=15&LH_BIN=1&_sop=15&_odkw=pc+to+converter&_osacat=0&bkBtn=&LH_ClassifyToggle=0&_trksid=p3286.m270.l1313
Jan 05, 2010 | Optoma Pico PK-101 DLP Projector
New beamer optoma hd65,message: no source found
adjust the resolution to match. also, make sure the monitor port is activated.
Nov 04, 2009 | Optoma HD65 DLP Projector
I have a Toshiba Satellite U300-13U. I cannot project from my laptop using my Optoma projector. I know how to use projectors and have necer had any problems with any other laptop. This isn't a FN/F5 issue,...
Check the video output by connecting an external monitor to the laptop. If you get a normal image on the monitor the the laptop video output is OK.
Use a different video cable between the laptop and the projector.
Maybe your laptop resolution is set too high for the projector.
This maybe a dumb question, is the projector video input set correctly?
Mar 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Projector will not read feed from laptop
hi
is this an optoma make , then yes it is amain board problem & it can be repaired.do let me know the model no
Feb 12, 2009 | Toshiba TDP-S8 Multimedia Projector
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Connecting a Optoma Projector to a Toshiba Laptop
I bought mine new... hooked it up and got the same response. I would have torn my hair out but I am bald! Checked everything. Great frustration. Finally, I thought to replace the cable with one I have on my monitor. Worked perfectly! A brand new cable and it was faulty! Contacted the company and they sent out a new one. Even sent a packet to ship my bad one back so they could find out what happened. No connection problems with the new cable.
Dec 18, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
