Question edited for a bit more clarity, but not sure what what you mean about 'wheels on earth' and 'will find but will not crank'?
Question moved to a Boulevard Category.
Do you mean it cranks, but doesn't 'fire' or start?
Your engine only needs three things
1. Clean fuel and supplied to the engine. yours is injected, so it needs fuel pump pressure.
2. You need Compression. You can measure that with a gauge.
Checkout this latest Tops & Tunics Product Name: *Fancy Graceful Women Tops & Tunics* Fabric: Rayon Sleeve Length: Three-Quarter Sleeves Pattern: Embroidered Multipack: 1 Sizes: XL (Bust Size: 42 in, Length Size: 27 in) XXL (Bust Size: 44 in, Length Size: 27 in)
Country of Origin: India Easy Returns Available In Case Of Any Issue *Proof of Safe Delivery! Click to know on Safety Standards of Delivery Partners- https://ltl.sh/y_nZrAV3
Find the service center, ask for their help, because there's nothing that you can do alone.The problems starts from the TV board, usually need to re-soldering.
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
yes, its dry solder joint problem in Vertical Deflection Area. If you know how to repair TV, then open it and resold vertical output IC pins and surrounding parts with solder iron and solder wire.
you may have a bad tuner that is the part that changes the channels. If there is the input jacks you can use them to input a VCR or cable box and use them as a tuner
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit.
The buzzing sound that you're hearing is the power supply overloaded.
Stargazer
