Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks under freezer of side by side
This happens 1-2x/day and is about 1 cup or less of total water. Could something be blocked due to ice buildup?
  • lauriebuchta Jun 18, 2009
    Hi--to clarify, there is ice on the floor of the freezer. It also seems that my food may be slightly defrosting b/c it is covered with ice crystals/frost. It does not appear that the water is leaking out the front of the freezer; it appears on either edge of the freezer, on the floor, but not in the middle.
    Thank you!!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is there a build up of ice on the floor of the freezer, or is there only water on your kitchen floor?
  • 1,543 Answers
It sounds as though you have a blocked up defrost drain.
Unload your freezer and remove the panel at the back. The defrost drain in a quarter size hole in the center back below the coils. It is most likely covered with ice now. Use hot (but not boiling) water to thaw it out. I use a turkey baster to flush the water into the drain until you can force water through it. After that, the water should run through the drain by itself into the drain pan where it will evaporate as the fan behind the refrig blows warm air over it.
Make sure you look at the coil area when you take the cover off to make sure water is not comming down in a frozen waterfall from the icemaker area.
Posted on Jun 19, 2009
  • 35 Answers
IS IT COMING FROM INSIDE ?? IF SO ITS A CLOGGED DRAIN IF ITS FROM UNDERNEATH IT COULD BE A HOLE IN THE PLASTIC TUBING
Posted on Jun 18, 2009
Ice build u p and leakage in freezer
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
Sep 01, 2012 | Refrigerators
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Leaking water from freezer
take back panel off inside freezer. you will see a drain tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off ice with a hairdryer and follow up with hot water till it flows away freely.
also check the drain tray heater is ok
Oct 13, 2008 | Refrigerators
Water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Mar 18, 2008 | KitchenAid KSRA25ILSS Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
