Question about Northstar Garden
Pulsating low pressure - Northstar Garden
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 | Garden
Clutch when disengaged pulsates an sometimes does it a low rpm
This is caused by the pressure. There are tongs that are on it in a circle. They are spring loaded. When one or some are weak or a spring has broken you will get a pulsating feeling in the pedal
Sep 07, 2011 | Chevrolet G10 Cars & Trucks
My karcher 250 pulsates when i turn it on, any idia how to fix it thanks
Several things can cause this problem. It is trying to build up pressure and something is preventing it.
1. check water pressure comming out of the the spicket.
2. Make sure the hose and connectors aren't leaking.
3. make sure there isn't any water leaking from the washer.
If all is ok I would guess the pressure pump has gone out that's the noise you hear pulsating trying to build up pressure.
Terry
Jan 15, 2011 | Garden
Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
2006 HSE RR....engine pulsates slightly when light acceleration
1. Fuel Pump pressure too low
2. Dirty air or fuel filter
3. Plug wires running parallel for more than 6" )cross em over each other or you get crossfire)
4. Crack in Intake manifold or split end on one of your vacuum lines or vacuum cap plugs
Check 'em out and let me know!
Jan 27, 2009 | 2006 Land Rover Range Rover
Garden Logo
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
