Question about Bosch Dishwashers
Bosch hmita22130 can only change power up, not down
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
Tip
Change the Sleep Button on the Start Menu to Shut Down
Want to shut down Vista with one click, instead of sleep.
Open Power Options in Control Panel
On the current plan your computer is running, click change plan settings
It will open Edit Plan Settings, find Change Advanced Power Settings and click on it.
Power Options will open, find the expandable tab that says Power Buttons and Lid, expand it.
Expand the tab that says Start Menu Power Button.
If you are running a laptop there will be two options, one for On Battery and one for Plugged in, click on the word sleep to open a pull down menu.
Click on the arrow, than Shut Down.
Click Apply and than okay. Close all Windows, Shut Down should be on the start menu instead of sleep
on Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
How do I change Bosch oven clock from military time?
We have an older Bosch Oven (maybe circa 2010), and the way to access the special settings is to hold down the "Temp" button for 2 seconds which reveals a hidden menu of goodies. I made two changes in there--changed it back to 12 hour instead of military time as well as disabled the annoying beeps every time you press a button. Manual is here: https://media3.bsh-group.com/Documents/9000369981_A.pdf
May 17, 2014 | Bosch Ovens
SDS drill variable power
Ok about changing the brushes but have you searched if the place where the brushes are located allow the brushes to move forward freely or they are in a way were narrowed so that the brushes can only move for few millimeters?
Mar 06, 2014 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
My HP G72 17'' shuts down about once a day
Is it overheating? Does it shut down when left unattended? Clean fan and vents. Improve air flow through laptop. Change power settings/Advanced Power Settings to High Performance and change Hibernate/sleep to never.
Dec 05, 2012 | HEWLETT-PACKARD G72260US Notebook
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
I have a bosch pb360 boombox that wont turn on with new batteries and the fuse is fine
There are two internal glass fuses inside the Bosch pb360sc.
If it won't power on, flip it upside down and remove the bottom section of the radio and four of the screws for the roll cage. Once inside you can figure out which fuse is dead and replace it. The Bosch manual is totally useless and does not tell you or indicate that there are any internal fuses. The fuse that runs the 12volt power supply / cigarette style outlet has nothing to do with your radio not being able to turn on/ power up. I guess they want their service partners to be able to jam you for .50 cent fuse....
Apr 07, 2011 | Bosch Audio Players & Recorders
When i want to shut down my netbook it wont shut down
If you need to do a hard shut down - you press and hold the power button.
It sounds like you need to adjust your power saving options in the control panel. You are looking to change what the power buttons do. Your power button can be set to "do nothing" when pressed or hibernate the computer or shut it down, etc. You also can have different settings for whether the computer is plugged in or not.
If you are in win 7 - go to control panel. Type "power" in the search in the upper right corner.
Choose "change what the power buttons do" from the list.
You can also access any other items you feel are pertinent.
Jan 10, 2011 | Toshiba Computers & Internet
Dishwashers Logo
87 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
