My sharp ar 5618 photocopier shows F2 error codes
My sharp ar 5618 photocopiers shows F2 error codes
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Posted on Jan 11, 2009
  • 87 Answers
SOURCE: Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Posted on May 23, 2009
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Sharp Photocopy AR 5618 showing L4 when on before it start photocopy
This is what the manual says when you het a message:
25385794-klcizou1qcaa2a3cc2pjju3n-5-0.png To read other interesting things in the manual is possible, because the manual is online (PDF) on this link:
http://www.sharp-cee.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5618-D-5620-D-5623-D_OM_GB.pdf
Jan 27, 2015 | Sharp Office Equipment & Supplies
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
F2 70 error code on sharp ar-5618, how can i resolve it.
i have sharp ar 5620n it is showing error f2-70 what might be the course
Sep 06, 2013 | Sharp AR-M277 Digital Copier Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
26 people viewed this question
jasbo
jasbo
