Question about Dishwashers
Maytag model #MDB7601AWQ Dishwasher
My 3 year old dishwasher will not start after you make your selection on what wash you want.I checked the door switch and float switch and they are ok.I changed the CPU board (It cost $74.00 on Ebay) and its still doing the same thing.I think it is the touch pad.I can not check the touch pad because the engineers that designed them made it so you can"t.I can not buy the start/display/detail touch pad unless I buy the whole complete thing that cost about $137.00.I am pretty good at fixing things but I am loosing my hair over this one.
    Master:
  • 529 Answers
If you think its the button...this can't hurt anything...Take a writing pen on the back end and push hard...If it clicks on a least you know the problem. I do this at gas stations that have these same kind if buttons....They get old and your finger want engage your selection... Just something to do before you go buy the whole panel.
Posted on May 08, 2017
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Posted on Feb 22, 2008
whytfang
  • 170 Answers
SOURCE: I have a maytag mdb7100Aww. Dishwasher leaks at bottom of door
You definitely have to have a clean......float clean from all debris...it is very typical for the float to cause leaking problems ..as it is an overflow switch....also drying agents...that are used...especially if any is spilled inside will foam up and cause an overflow as well as liquid detergents that are not specified by the maker of your DW....these foam also....(if to much is used)...but the float will not push down on the switch if it is completely free from gunk.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Posted on Mar 29, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
  • 22 Answers
SOURCE: Maytag MDB9150 Dishwasher soap dispenser door doesn't open
the plastic lock of the soap dispenser in side the dish washer door is broken
Posted on Jun 09, 2009
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
Our Maytag dishwasher model MDB4000 leaks from the door, but not every use. The leak started just on the left corner, but now sometimes leaks from the middle. The diswasher is 12 years old.
Usually this is caused by a bad door seal.
It can easily be removed and replaced.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Maytag MDB6000 Dishwasher
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Dishwasher is leaking from under the door
the lower door seals may be damaged or contaminated with old food debris. also check the "n" seal around the door are clean.
Mar 18, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Maytag diswasher problem
liberty, it sounds like your keypad is bad, here is your tech sheet for your dishwasher, it will give you detailed instructions for checking it out. Catriver
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Jan 18, 2008 | Dishwashers
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
228 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
