Question about Lands Phones
Remote access for xd8500 how doo you access your messages
Far did'the install Lexmark x8350 all-in-one
Often, changing your operating system can result in driver issues. If Lexmark cannot or will not help you out you are in deep doo doo. U can either get a new machine to work with Win 10 or go back to your original OS.
Jul 13, 2017 | Lexmark Office Equipment & Supplies
How to remove a keylock on Dixon plasma tv without remote all the buttons are not working and l cant switch it on?
On many of the newer sets without a remote you can be in deep doo doo. And to complicate matters your set controls are also bogus.
Anyway you can get a remote for the set? Try ebay? Google it? Manufacturer?
Idea - try a hard restart on the set to see if that frees up the internal computer.
Apr 30, 2017 | Televison & Video
Hello, I have a home theater coby dvd765. Unfortunately the remote control is deprogrammed. Could you tell me how reprogrammed? Thank you
Unless you can get a manual or google an answer you are in deep doo doo since Coby went bankrupt and is out of business.
Feb 22, 2017 | Coby Audio Players & Recorders
Coby. How do I unlock it?
U are in deep doo doo since Coby went bankrupt and is out of business. U might want to check ebay for a remote but I do not know if that will take care of your code problem.
Jul 31, 2015 | Televison & Video
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Hello I was wondering how to use the VM acess with my phone. I want to be able to call from a different number and listen to my messages how do I go about doing so
I have a similar model. You need to configure a remote access code on the phone. Then, when you call your phone, you enter the pin after your message starts.
(From the manual)
Using a touch-tone phone, you can call your phone number from outside and access the unit to listen to messages or change answering system settings. The unit's voice guidance prompts you to press certain dial keys to perform different operations.
Remote access code:
A 3-digit remote access code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. The default
setting is "111".
Important:
To prevent unauthorized access to this product, we recommend that you regularly change the remote code.
1 {MENU} {#} {3} {0} {6}
2 Enter the desired 3-digit remote
access code.
3 {SAVE} {OFF}
Below is a link to the manual. The remote access instructions are on page 35.
http://static.highspeedbackbone.net/pdf/KXTG4031-MUL.pdf
Mar 05, 2011 | Panasonic KX TG4031 Cordless Phone
The wheels have stopped spinning on the remote contol mystery machine. How do I repair this?
If you've been running it on carpet then you have fibres wrapped around the axle. cut them off with an x-acto blade and you'll be good. If that's not the problem you may have stripped a plastic gear the motor goes on. If you have other dead r/c cars around you might be able to use a gear from one of them to fix it. Otherwise contact the manufacturer for a replacement gear.
Hope this helps!!
Nov 29, 2010 | Scooby-doo Scooby Doo Remote Control...
Cant get remote access working Binatone Symphony 2210 cordless ph
If you have set up the TAM settings correctly then it seems to be a fault with the machine. I've set up my TAM settings with new pin and I still can't remotely access the messages.
Make sure you are pressing the * key before you enter the default code (as far as I can recall).
Apr 05, 2010 | Lands Phones
Lands Phones Logo
13 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
