Excell VR2522 Pressure washer - sudden loss in pressure.
The pressure suddenly dropped and there was a hissing or whooshing sound from the pump. Washer is about (3) years old and has maybe 15-20 hours on it. I've heard this pump is notorious for failing early.
Re: Excell VR2522 Pressure washer - sudden loss in...
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
You'll need to know who manufactured the motor (Honda, Briggs & Stratton, etc) along with the model and serial number. With that information, you can do an online search for small engine repair manuals and retrieve the specs for you particular motor.
You can even call your local outdoor power equipment repair shop, they'll provide you answers to your questions.
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
That pressure washer uses a Honda 5.5 hp overhead cam engine You need to get the model number of the Honda Engine and thenClick Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
Need replacement part but I need to know where the serial no is located
