Question about HP LaserJet Office Equipment & Supplies
Hp laserjet beeps
Beeps
HP LaserJet 4350dtn
Typically the only reason that a printer beeps when printing is because you have the printer plugged into a UPS. None of the circuit boards on the 4350 have any sort of audio capability. Plug the printer right into the wall outlet.
Sep 22, 2016 | HP LaserJet 4350dtn Printer
Laserjet 4100 Has an annoying beep on print. How do I disable it?
The plug needs to be into the wall outlet. If it is in a surge protector, the electric flow can be interrupted and cause the beep.
Nov 27, 2014 | HP LaserJet 4100 Printer
How do I stop the printer beeping
No beep facility for lj 1020... chk model
Oct 03, 2014 | HP LaserJet 1020 Printer
Hp p2055dn beeps evertime something is printed. Can i disbale the annoying beep?
I had the same problem. According to HP, their printers are very picky when it comes to power. (no battery back up, power strips, etc...) I had my printer plugged into my UPS. I unplugged it from the UPS and plugged it back in directly into and outlet. The silence while printing was blissful.
Feb 17, 2011 | HP P2055DN LaserJet Monochrome Printer
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
HP laserjet 3055 beeps loudly when printing. Would like it to stop!!! Otherwise printer is just fine.
If it's a grinding or squeaking problem, it's a pickup roller assembly problem. Would need to be serviced, or returned if still under warranty.
Jun 26, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
My HP Laserjet 2840 all in one beeps when printing
unfortunately, your printer uses all of the carts even for just black prints.
press the check mark key and scroll down to diagnostics.
select disable cartridge check
But then you won't know when you're out of a certain color.
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
19 people viewed this question
Seeker5211
Seeker5211
