Question about Amana 3.2 cu. ft. Top-Load Washer
Water drips into the washer when not in use.
It appears to be coming from under the lid, where there is a plastic strip.
  • 20 Answers
Your fill value are going try replaceing the fill value,it is the one were the hoses hook up to on the back of washer
Posted on Jun 20, 2009
Water is dripping into the machine. Appears to be where water comes into the washer through a hose in back top of washer
Close the water tap that supply water to the washing machine, then try to tighten the plastic screw that connects to the machine. Test again if there is any leak, if there is, replace the washer that stays in between the plastic screw and the connection point of the washing machine. This should solve your problem. Good luck and if you have any other question then please feel free to ask.
Jan 11, 2011 | Washing Machines
A SMALL DRIP CONTINUES TO COMe out of the drain valve. I drained the tank and refilled it but it continues to drip. It appears there is a white plastic drain knob which is where I attach my hose to drain...
Hello CHUCK The drain can be replaced with a LONG stem brass hose bib.The plastic is a piece of s*#$.They also sell brass drain caps for a easy way out.Just screw it on.
Aug 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water drips into tub of machine when machine is off. The only way to get the water to stop is to shut off the water supply line to the washer. The drip is slow and seems to be coming from near the...
Water valve letting by, could be diaphragm split or filter
partially blocked causing too little water pressure to hold the valve closed
Strip valve and clean, check neoprene diaphragm.
or replace valve.
Feb 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Washer drips after cycles are completed.
yes the water inlet valve is bad! might be easier to remove the base, when you remove the base the back stays connected to the frame. just unplug the machine,remove the end caps on your control panel and remove the screws holding it on, them pull slightly forward and up to fllip the control panel back it has plastic hinges on top,be careful not to break them. then unplug your lid switch, with a screwdriver remove the 2 gold clips that hold the base to the back panel, then open your lid lift from back towards you and the whole base will come off leaving the back panel and frame, should be a whole lot easier to replace the valve, then replace reversing your steps , when you are lifting off the base look at the bottom of machine through your lid and you can see how to put it back on the frame! not to hard!
Feb 17, 2010 | Kenmore 24902 Top Load Washer
Water on floor under washer
re; water under washer.
The ammount of water is from 1/4 to 1 cup after an individual load. It only became noticable reciently, after the last 3 or 4 heavy loads, using the manual setting on next to the top level. There is an automatic function, but due to the dirt and grit in the jeans I use manual.
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL08 top load washer appears a crack in the inside water dispenser
With the lid open, you'll see two white plastic plugs on the top front lip of machine. Pry them up with fingernail to reveal screws to remove. Take care not to let top flop back as plastic tabs may break.
May 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
89 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
