Question about Yamaha Audio Players & Recorders
Flat belt for yamahadeck kxr 700 - Yamaha Audio Players & Recorders
  • Yamaha Master
  • 1,258 Answers
Go To Marrs Communications and order the belt kit- that is the easy way.
Posted on Jan 02, 2015
I lost all forward and reverse drives. u joints intact. thoughts?
best guess, this belt broke
http://www.ebay.com/bhp/polaris-sportsman-700-belt
Mar 08, 2015 | Polaris 2007 Sportsman 700 EFI
Pioneer DVL-700. Unit Plays LD Discs & CD's fine but will not play any DVD Videos.
The dvd's are not spinning up correctly. If the belt inside is worn this will cause cd's to play but dvd's fail. open up and replce belt (small black rubber running on motor)
May 11, 2011 | Pioneer DVL-700
Dryer squeals and squeaks while running
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Oct 04, 2010 | Kenmore 700 6972 Dryer
Drier had a high shrieking noise. Noise stop now it's a knocking sound
If you have a front loading machine,
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console will stay with it.
Remove the screws holding the lint filter housing in place, and remove the lint filter.
Please rate me
Sep 07, 2010 | Kenmore 700 6972 Dryer
I have a 1993 subaru legacy wagon and just had the belt(s) for the alt and a/c replaced and Midas says I should replace the "serpentine" belt now too for a cost of $700. Does the car have a serpentine...
Your car does have a serpentine belt, and it costs like $12.00 new. I had a friend of mine who was a mechanic, and he put mine in when it went bad for free. It didn't take him very long, so I'm not sure how that $700 estimate can be accurate. Even if you bought a belt at a store and paid $75/ hr labor at a garage it shouldn't over $100...It just doesn't take that long. You do need a specific tool for the belt tensioner, but Midas is trying to rip you off.
Aug 16, 2010 | 1993 Subaru Legacy
Walking belt for vitamaster 700
ultrafitness equipment.com we got belts cheep 4 every make and model
Jan 27, 2010 | Exercise & Fitness
Broken belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Dec 02, 2009 | Kenmore 700 6972 Dryer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
How to clear the full memory on my Panasonic electric typewriter
To clear ALL memory, turn the machine off, then hold down the SHIFT and CODE keys while turning it back on.
Here's a halfway measure. While in normal typing mode, hold down CODE and touch TAB CLEAR to clear all tabs and margins at once. Does not affect any stored text memory.
These work with the KX-R340 and all the KX-E series. I presume they'll work with your KX-R440 also.
Eric
Nov 28, 2008 | Office Equipment & Supplies
52 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
