Question about Pyle Car Audio & Video
Rear camera wiring from head unit
Where does the rear wire coming out of head unit connect to?
james klgr
  • 362 Answers
SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
SOURCE: Kenwood CD changer wiring diagram
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Posted on Jan 18, 2008
SOURCE: head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Posted on Mar 13, 2008
jamesmac
  • 71 Answers
SOURCE: wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Posted on Sep 09, 2008
  • 5 Answers
SOURCE: how do i wire 6x9 from the back shelf to the head
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Posted on Feb 28, 2009
When I power up the unit, the camera is displayed immediately, the backup wire turns the screen off.
There's a wire in the head unit harness that's meant to be connected to the vehicle's reverse light wire. If you don't have a rear view camera, this wire should not be connected to anything.
Aug 06, 2015 | Pyle PLCD23A CD Player
Have sony xav-60 head unit trying to install a rear view camera, but having issues getting unit to switch over when in reverse what wires need to go where camera has yellow video output 1 red wire, 1 black...
You might try the truly wireless QuickVu(TM) Wireless Backup Camera. Run the yellow RCA cable from the receiver to your Sony unit, if it has an RCA input. The QuickVu camera has no wires, so that part is really easy. Buy direct from the manufacturer!
Aug 12, 2013 | Sony XAV-60 Car Video Player
Problem w/ my xplod amp
To wire correctly, I have the same xplod amp in my car.
Phono leads connect to the output terminals on the back of your head unit, Then connect to the input terminals on your amp.
The remote wire connects to the amp remote wire behind your head unit (if don't have a wire labeled amp behind the head unit then it usually a blue and white wire).
The power lead from your battery connects to the 12v or PWR terminal on your amp.
Then the Ground wire connects to a rust, dust and paint free area on your car (bolted down), Try behind your rear seats and find a bolt already there. This wire then connects to the GRND terminal on your amp.
Hope this helps.
Feb 03, 2013 | Car Audio & Video
I have a JVC head unit for my car its the 720 unit anyways i have bought to wiring harness for my 2005 gmc sierra slt and the one it powers on but no sound comes out this is made by pac the other one is...
if you keep guessing you are going to fry the head unit.there is 3 plug ins on most wiring harnesses,they are made for two fit different yr gm cars.one plug for power supply and a second for speakers the 3rd is not used.they will only plug in one way.speakers should be wired the speaker wire,one has a line on it ,use that wire on each speaker for ground and the solid colored wire it a plus or poss.wire,on each speaker the same way.also make sure the head unit is grounded good.take your time the harness comes with the instructions.follow them to a T.i have a feeling that the wiring is not being matched up right.it is not in the harness your buying.triple check all wiring connections.hope it helps.PS IF YOU CAN SMELL ANY BURNT SMELL COMING FROM REAR OF HEAD UNIT ITS COOKED.HOPE I COULD HELP.
Dec 22, 2010 | JVC Car Audio & Video
Rear speakers do not work
Either the balance is off on the head unit, or the the out puts (in the head unit) for the rear speakers are blown.
May 15, 2009 | 2002 Mazda 626
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Someone gave me a Pioneer DEH-2700 head unit and didn't have any of the manuals. I have a 2007 Chevy Cobalt How to I install this unit into my car. I don't know which wires go to what or anything
the easiest way to solve this issue is to buy a wire harness for your car this will make the install alot easier. Its already color coded for your wires, so head out to your local installer or try best buy you might also need a stereo kit. Email me with questions on installs. jerree_cardenas2006@yahoo.com
Jul 25, 2008 | Pioneer Car Audio & Video
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Rear view camera
The unit uses a wire from the back of the head unit to connect to the vehicle wire that sends voltage to your reverse lights. If this wire isn't connected or isn't connected correctly, the head unit can't tell when your vehicle goes into reverse. Most installers don't bother with that wire if the unit isn't being installed with a back-up camera.
Feb 25, 2007 | Jensen VM9020TS Car DVD Player
Car Audio & Video Logo
23 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
