Question about Xerox Office Equipment & Supplies
Ip6220d error code 6500 - Xerox Office Equipment & Supplies
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. this is what other people are saying to.
Jan 29, 2011 | Canon PIXMA MP830 All-In-One InkJet...
When i turn on my printer it says error code 5100 how do i fix it
Copy and paste the following address for Canon support:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=11863#SupportDetailAct
Input query: "error 5100" Click "Search" button
Review the solutions
Dec 05, 2009 | Canon PIXMA iP6220D InkJet Photo Printer
Canon printer error code 5100 while attempting to put in the color and photo cartridges. pix ip6220d is the printer model number
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width) The unit is not homing, check for obstructions.
Nov 21, 2009 | Canon Office Equipment & Supplies
Officejet 6500 error code 0x61011beb
General error 0x610000F6 actually is a Carriage Jam issue
Click Here for troubleshooting.
Nov 11, 2009 | HP Officejet 6500 Wireless All-in-One...
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
Oct 08, 2009 | Canon Office Equipment & Supplies
Canon PIXMA iP6220D
Hi You can Try
This post is old
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 02, 2008 | Canon PIXMA iP6220D InkJet Photo Printer
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
Dec 21, 2007 | Canon PIXMA iP6220D InkJet Photo Printer
24 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
