Question about JVC HR-S7600 S-VHS VCR
Tape ejects immediately - JVC HR-S7600 S-VHS VCR
When I put a tape in, it immediately ejects it.
Try to find out, where the tape drive stops and why. If there is debris in the recorder it could fake the tape is not going where the recorder expect it to go. There are lots of reasons why the recorder will spit out the cassette. In the first place it does so, to protect the tape for damage, because the sensors don't sense a normal flow of the tape.
Mar 04, 2015 | Emerson EWV603 VHS VCR
Vcr keeps ejecting any tape I put in
damaged pinch rollers and play/record heads. Replace both sets.
Oct 25, 2009 | Televison & Video
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
Tape holder jammed
remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Jul 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
JVC HR-S7600 S-VHS VCR Logo
26 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
