Question about Festina Watches
Watch stopped working - Festina Watches
I received watch for x mas and Sat 4/2 it stopped wound it and it stopped again 4/4 is it not getting enough light or do I have a bigger issue. Thanks
Eco-drive watches do not need winding or batteries, so if you are winding it to make it work, then it is not a true Eco-drive watch.
Apr 04, 2016 | Citizen Eco-Drive watch
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
The watch is self widing. ait just stopped working
Yes I do. Don't try to fix your watch.
My watch maker friends have told me that generally speaking, the reason most self wind mechanical watches stop is: (1) they need cleaning or (2) the screw that holds counter weight in the watch (that actually does the winding) comes unscrewed. He said most of the watches that have been worked on by the customer have lost the screw.
My advice remains have your watch looked at professionally.
Any other concerns my friend?
Jan 14, 2010 | Watches
Seiko premier chronograph constantly stop working
take watch to a jeweler, or pawn shop and have it cleaned and oiled.
Aug 04, 2009 | Seiko Premier SKP085
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Automatic Watch Stops
There can be hundereds of causes why your watch isn't working properly, so, I'll not name them.
One is clear- without help of skilled watchmaker your watch will NEVER work properly.
NOTE: It may sound very strange, but mechanical watches do NOT like to be left without job.
Next time you decide to leave mechanical watch aside for long time- do not forget to wind it up once in a 2-3 days even if you are not wearing it.
This will help to prolong watch movements life and keep timekeeping steady and accurate.
Regards
Arthur
Dec 15, 2008 | Invicta (2540) Wrist Watch
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Dec 03, 2006 | Fossil FS3105 Wrist Watch
Watches Logo
16 people viewed this question
Top Festina Watches Experts
Ansel Alberto
Ansel Alberto
240cpa
Are you a Festina Watch Expert? Answer questions, earn points and help others
