Question about ASUS M2NPV-VM Motherboard
Turn on ahci mode - ASUS M2NPV-VM Motherboard
How to change the ide mode into ahci on the bios?
If the BIOS supports it, the option is usually available in the advanced options area. Each BIOS is slightly different. Be advised, however that switching the mode from IDE to AHCI will result in Windows not booting if already installed. The two modes are not compatible. Using AHCI will result in needing to reload the OS. Also ensure that you backup all data on the disk as well to prevent data loss.
Feb 16, 2016 | Computers & Internet
What is sata mode for this machine ide mode or ahci mode
AHCI (Advanced Host Configuration Interface) is a standard that defines SATA configuration. IDE mode is used when a host computer doesn't support sata drives. Every OS post Windows XP can handle ACHI or sata mode.
Apr 05, 2015 | Computers & Internet
Is Asrock 945GCM-S compatible with AHCI?
I think that you motherboard BIOS can supprot that,
Access your BIOS and look for SATA Mode option, and change it to AHCI
Jan 17, 2013 | Asrock 945GCM-S Motherboard
How to set up AHCI mode In RS482M bios.
Hello from here you can download a manual:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=536&DetailName=Feature&MenuID=24&LanID=0
If the bios is set to IDE/sata mode it will not boot when you select the ahci mode.
Your windows has to be installed again when the settings are made in the bios in order to make the ahci mode working.
More about ahci here:
http://en.wikipedia.org/wiki/Advanced_Host_Controller_Interface
Good luck
Dec 22, 2012 | EliteGroup RS482-M (RS482M10A) Motherboard
Turn on AHCI mode
It should be in your BIOS if it is there to begin with? gl
Dec 07, 2012 | PC Chips PCChips A13G+ v3.0 Motherboard -...
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
Can not get it installed on Note Book computer
You should go to BIOS and set "mapped as AHCI" to SATA/IDE mode". Find any information regarding AHCI, SATA/ID mode or anything like that on your BIOS. then try to install Windows XP Home Edition
Aug 24, 2010 | Microsoft Windows XP Home Edition
Trying to install vista 32 bit on my Gateway DX 4720-03.Vista won't install because it can't see Hard drive. How do i disable ahci or sata mode in the bios or is there a work around to install Vista32.
Vista will have the drivers necessary to identify SATA/AHCI controllers, built-in by default. It would not be necessary to turn the AHCI mode 'off' or to 'ATA' mode (unless you get a 7B or inaccessible boot device BSOD). Check if your system has a RAID configuration, in which case there may be a 3rd party supplied RAID driver that you need to install first. Also, check if the HDD cables are connected properly & the HDD is detected in the BIOS (System setup screen) first.
Mar 16, 2010 | Gateway DX4720-03 PC Desktop
Could not make it work in AHCI mode
what kindda chipset your laptop is?
It's must obtained in your OEM site
Jan 20, 2009 | Acer Aspire 4530-5889 Notebook PC
ASUS M2NPV-VM Motherboard Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
