Question about Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook
My toshiba laptop will not start up only get the toshiba screen with f2 and f12
  • 277 Answers
There are potentially two different issues: A power controller failure, or a FSB malfunction. Both have sollutions and I wrote extensive guides with photos and everything. Both require only time and skills, so the fix is not like the repair centers' do it by changing the motherboard and charging $300. You'll be basically repairing the motherboard instead of replacing it.
Bad power controller: http://imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
Bad FSB: http://imateski.blogspot.com/2009/03/fixing-non-responsive-hp-nx61106xxx.html
Posted on Dec 19, 2009
  • 43 Answers
If you press F12 and take the option to boot from the HDD - does it?
Posted on Jun 18, 2009
4 Suggested Answers
ibleedblue18
  • 50 Answers
SOURCE: Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Posted on Dec 07, 2008
  • 73 Answers
SOURCE: Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Posted on Feb 08, 2009
  • 540 Answers
SOURCE: When I turn the laptop on (L350) the screen starts
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Posted on Feb 09, 2010
Toshiba Satellite L355D-S7815 had windows 8, opened up laptop and cleaned all the dust out and now when i turn the laptop on it shows the Toshiba screen but no F2 or F12 option's.
What you are talking about is called no POST. You either shocked the cmos and the bios wont load or something is not hooked up right.
Mar 21, 2013 | Computers & Internet
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
Tecra m1 boot option
when computer starts up push f2 or f12 what ever your boot formate is on system its the lower left side of screen when first starts up.
Feb 17, 2011 | Toshiba Tecra M1 PC Laptops
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Grey screen with white line on my laptop
I took the battery out then put it back in and it works fine now.
Apr 28, 2009 | Computers & Internet
Starting problem
not sure on model what f2 or f12 is
f2 enter bios
f12 choice menu
options:-
re-install xp
repair xp
flash bios
Jan 06, 2009 | Toshiba Satellite A135-S4527 Notebook
Cmos setup screen
If you're trying to get to the bios set up, when the initial Toshiba screen comes up it will tell you what to press for the set up towards the bottom of the screen.
Jul 24, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue  PC Notebook Logo
171 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
