Question about Garden
Craftsman lt1000 My mower starts and runs great for 20 minutes then starts to rev up and down, up and down then dies, I have to wait for about an hour to run it again then does the same thing after 20 minutes. Any ideas?
    Problem Solver:
  • 7 Answers
If it has overhead valves, get the specs from the engine manufacturer and reset the valves. this should cure the problem.
Posted on Apr 16, 2014
  • 74 Answers
SOURCE: lawn mower runs well from cold but if stopped won't start
Sounds like it's running rich. If the mixture is slightly rich it will start well when cold, but when hot it floods. Check the air cleaner to be sure it's not clogged/blocked. Get a new plug for it and if this happens again just install the new plug - the new plug won't be fouled with fuel. If it started with the new plug then you're on your way to a carb adjustment (that is if the air filter/cleaner is clean)
Posted on Aug 29, 2009
  • 67 Answers
SOURCE: Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Posted on Sep 01, 2009
  • 54 Answers
SOURCE: I have a John Deere riding mower with a B & S
Possibly a restricted carb, or float level (if it as one).
Posted on Apr 28, 2010
  • 252 Answers
SOURCE: my craftsman lawnmower 917.378941 runs about 10-15
provided fuel flow is consistant and fuel tank beather is clear
sounds like the magnetron coil assy is going open circuit when hot
replace the magnetron with same type of unit as fitted to engine
two types could be used
1, standard magnetron ( has a piece of card between the halves of the iron lamination stacks
2 advancing style magnetron this unit looks like the standard one
except it has no card and has a wideish back gap at the ends of lamination stack
which ever one is used use same type
here is web site for parts
http://www.briggsandstratton.com/maint_repair/manual_and_more/
enter model and type numbers from blower housing on engine
good site check it out
cheers paul
Posted on Aug 02, 2010
  • 2239 Answers
SOURCE: cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
Posted on Apr 14, 2012
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Put a new coil in my craftsman Lt1000 still have
Try leaving the fuel cap loose, its possible you have a blocked fuel cap vent which can be cleaned with compressed air. Also if it still dies,check to see if you have spark while its hot. Also check for correct valve clearances. Hope this helps, regards Phil.
Jun 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Lt1000 with 21hp keeps wanting to die after 5-10 minutes, battery, plugs and air filter has been replace, any help would be great.
Have you replaced the fuel filter? My 21 horse did the same thing until I put in a new fuel filter.
HOpe this helps.
Aug 19, 2009 | Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
