Question about 2008 - 2010 Mercedes-Benz C300 Tire Pressure Monitoring System TPMS
2009 c300 mercedes tire pressure monitoring system
Intermittently comes on
  • 20 Answers
Either one of your tires is losing air pressure slowly or you could have a tire pressure monitor (which is in the tire) going bad. Check your tires for any foreign objects eg. nails, screws, shards of metal.
Posted on Nov 24, 2014
Why won't it go back into reverse or park sometimes?
My car won't go into reverse or park... Sometimes, happens ...
repairpal.com > ... > 2011 Mercedes-Benz C300 4MATIC
Jun 5, 2015 - And I know that there is no transmission problems just in my gear shifter. I can't figure it out. ... 2011 Mercedes-Benz C300 4MATIC Questions ...
Mercedes Benz automatic transmission shifter shaft bushing ...
? 6:07
www.youtube.com/watch?v=vQ-yupz08Tw
May 25, 2012 - Uploaded by fupabox
I have a 1997 c280 without the key being in the ignition and foot on the brake I'm ..... get the shifter to engage in reverse or park, it will only go into neutral and drive. ... I have a 2009 c300 and it has problems going into gear. .if I wiggle it .... Mercedes Benz 722.6 transmission..stuck Shifter mechanism repair .
Oct 22, 2015 | Mercedes-Benz 2009 C300 4Matic Sedan
How do you reset tyre pressure warning signal on a 2011 merc c250
It should reset when the tires are properly inflated. If not, you may have a bad TPMS (Tire Pressure Monitoring System) module--usually the sensor in one of the wheels. Might as well go to the place where you get tires, since the tire must be dismounted to replace the TPMS sensor.
This article http://www.discounttire.com/dtcs/infoTPMSArticle.do platesDiscount Tire explains the system in a little more detail.
Feb 28, 2015 | 2012 - 2012 Mercedes-Benz C250 Tire...
Mercedes 2009 c300 won't start which fuse
i have mercedes c300 2008 . on my dash default withholding system and d'not start what is the problem with my car
Jan 21, 2013 | 2009 Mercedes-Benz C-Class
Has anyone have the chart for fuse of driver side fog lamp in 2009 Mercedes C300 4matic
Sorry, no chart. there are three fuse boxes. One is on the side of the dash by the steering wheel (L/H drive), one is on thew firewall L/H side under the hood, and one is in the trunk R/H side. The fuses should be listed inside the covers. Hope this helps. Owners manual at http://www.mbusa.com/mercedes/service_and_parts/owners_manuals Page 372. You may find, as this is for fog lights, that it uses a cicuit breaker rather than a fuse
Jan 05, 2013 | Mercedes-Benz 2009 C300 4Matic Sedan
ABS Light is on dashboard
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System
Nov 01, 2012 | Cars & Trucks
Where can I find a 2009 Mercedez c300 fuse chart which is missing from my car
Have you tried looking in your Owner's Manual? Many modern vehicles only give fuse numbers on the fuse boxes. The chart to see what these fuses go to are usually in the Owner's Manual.
Please note that there are 2 different models of a 2009 Mercedes C300. There is a C300 4MATIC(204.081) V6-3.0L (272.948), and a C 300 (204.054) V6-3.0L (272.947).
There are also 3 different fuse boxes in your vehicle. It would be helpful to know what it is you are looking for so the fuse location can be looked up.
Please also review this article:
Where's The Fuse?
Sep 18, 2011 | 2009 Mercedes-Benz C-Class
What is TPMS ,I get this indication light on ,thanks for your help
TPMS stands for "Tire Pressure Monitoring System" it means u have a tire low on pressure.
Jul 29, 2010 | 2009 Kia Spectra
Reset tire pressure monitoring system
after you have inflated the tires to the correct pressure press the tire pressure button for a few seconds untill you hear a beep sound .that indicates the tire pressure has been reset. hope that helps
Dec 22, 2009 | 2009 Volkswagen Tiguan
A dash lite on my 2009 hyundai sonata came on while was driving. if you can tell me what it is TPMS
stands for Tire Pressure Monitor System= TPMS. check all tire pressures (when cold if possible) and adjust them according to the tire pressure sticker on the drivers door jamb,glove box,another door jamb or center console compartment(inside).even check the spare tire pressure. the lite comes on to tell you that either 1 or more tires is considerably lower or higher in pressure than the rest. once u adjust the pressures correctly,look in the owners manual as to how to reset/shut off the light. on alot of cars if u drive the car for awhile the light will reset and go off .hope this helps.
Aug 31, 2009 | 2009 Hyundai Sonata
2008 - 2010 Mercedes-Benz C300 Tire Pressure Monitoring System TPMS Logo
138 people viewed this question
Top Dorman Vehicle Parts & Accessories Experts
yobo007
yobo007
cgswift
Level 1 Expert
Willie Keisser
Are you a Dorman Vehicle Part and Accessory Expert? Answer questions, earn points and help others
