Question about Apple Cinema Display 23" HD Monitor
23" monitor was flashing 3 times
I followed the instructions on solution #1 and powered the computer down and re seated the monitor. It is fixed !
  • 41 Answers
Great!!
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Posted on Jun 18, 2009
Free download norcold n611 rv refrigerator manual
DOWNLOADS
Parts List-06-08-12Reference6/13/2012669.77 Owner's Instructions - Cooling Unit InstructionsTechnical7/12/200728.17 Installation Manual - 3/23/06 - 2/19/07User Manual7/12/2007872.04 Installation Manual - 8/2/04 - 3/23/06User Manual7/12/2007791.81 Installation Manual - CurrentUser Manual6/16/20091,239.84 Installation Manual - Through 8/2/04User Manual7/12/2007508.79 Owner's Manual - 3/23/06 - 2/19/07User Manual7/12/2007370.63 Owner's Manual - CurrentUser Manual1/20/2010630.82 Owner's Manual - Through 3/23/06User Manual7/12/2007394.09
I believe you can find the fault codes above. Here is a link to the Norcold N611 Information and Contact Page
Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
Monitor power light flashes off and on. Monitor
It could be any of the two. As a troubleshooting step, and I have seen this before, try connecting the monitor directly to the wall outlet and this being a new outlet. (sometimes a power issue)
Do you have a extra power or monitor cables to rule out a cable problem?
The VGA card could be mis-seated. Turn off the computer and re-seat the video card.
Does the monitor screen show at Bios and is the problem only in windows? (in case higher resolution settting than monitor can handle)
Jul 11, 2009 | Star Logic Monitor
Monitor goes through a rainbow of colors when shut off; till power shut off.
Try your monitor on other desktop or laptop, if the problem persist - change the monitor or borrow one and try it on the same computer as it could be your video card. hope this helps...
May 25, 2009 | Dell Dimension 3100 PC Desktop
Apple 23 monitor 3 blinks and then pause, top screen is dim.
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Apr 04, 2009 | Apple Cinema Display 23" HD Monitor
Pl2010m
This is the same problem I've seen several times. Fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they just can't keep up.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company also. I've seen a lot of complaints for this "international" company.
The fix for most of the problems on these monitors is about $8 on new capacitors (Plus shipping).
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors.
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
-Chip
May 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
When I went to use my destop am5100 - b5303a desktop thee light was flashing but couldn't get a signal to monitor reboot the unit twice then shut down the power supply and now the on light doesn't flash...
did you confirm the cable running from the video port on the computer to the monitor is firmly attached? Also did you hear any beep codes. What video card are you using and what operating system. Most likely this problem is 1. bad connection from pc to monitor, 2. graphics card not seated properly in it's slot or 3. defective graphics card. 1 and 2 are easy to fix (1 - tighten connection, 2 - push card back into it's slot on the motherboard) and the case of 3 you'd need to get a new video card.
May 03, 2008 | Computers & Internet
Mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Mar 29, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Apple Cinema Display 23" HD Monitor Logo
534 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
