Question about Maytag SAV571EEWW Washer
How do i locate my fuse on a maytag washer model number LSE7806ACE
AT702
SOURCE: Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Posted on Feb 01, 2008
SOURCE: Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Posted on Jul 11, 2008
SOURCE: Washer won't agitate, drain or spin
Hi Xinia_s
The lid switch needs to be replaced. although it seems to be working for the water intake valves it will not work for the motor. it is not the fuse. the main fuse sits right above the motor's start capacitor in the lower left side of the lower cabinet; had it been the fuse it would'nt even fill w/ water. have the lid switch replaced and it should do the trick.
Posted on May 02, 2009
arikrom
  • 528 Answers
SOURCE: Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Posted on Feb 22, 2010
  • 5 Answers
SOURCE: Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Posted on Sep 13, 2010
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Washer does nothing when you pull the button to start
It is probably the lid switch. On some machines there is a lid switch fuse that may not be in your wiring diagram for your machine.
Some of the fuses are glass and look like an automotive fuse and there are some enclosed in the switch assembly that you can't see unless you drill out the rivets holding the switch together.
It is a carbon fuse with a spring on each end pulling on it.
I had the same problem with mine and Maytag tech told me there was not a fuse in the switch.
This made troubleshooting especially frustrating.
Apr 15, 2009 | Maytag Performa PAV3200
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
it only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here www.repairclinic.com/SSPartDetail.aspx?s=t-LSE7806A-%3d%3di435797&PartID=435797 this is what you need to check.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag SAV571EEWW Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
