The monitor is not working,so is themouse keyboard and theDSL modem /the computer fnas are working theHD sounds like is spining/can it be fixed or replaced ?
  • 7 more comments
  • El Greko Jun 18, 2009
    I conected all to a Dell opt... GX110 ,including a printer and nown everything works,believe me iI have done all the possible to resolve this in the laS 3 DAYS friends tell me to buy another Brand computer what do you suggest ?
    OS Windowsm Vista Gateway GM5664
    the only issue was,that m u daughter plug something in the wrong place not where it belongs,I do not know what it was Wndows Vista Gateway GM5664
    If connected to another computer everything works just fine
    the monitor lits and is connected is black like there is no connection with the computer,regularly when I turn on the computer evrything lites up,not in this case,it is just as if the where not attached to it or connected ;these do not work at all with these computer CAN YOU HELP ME ?
    Not a thing appears on the screen,I have benn working on these for the las 3 days not including today (it is just not working)
    Can any one help an d give some idea about mu problem,Thanks either way(can you or not)
    the monitor works wit another computer;it is not the monitos it is probably the BIOS
  • El Greko Jun 23, 2009
    Iposted enough information about my problem and I gor answers NOT related to the problem as a whole/can you gime a better idea (solid idea
  • 1,272 Answers
It seems that the concerned computer is not booting up. Disconnect the power to the computer and open the case.
Remove the memory sticks and then plug them in more securely.
Reconnect the power and check if the computer boots up
Posted on Jun 23, 2009
    President:
  • 2,653 Answers
The problem is most likely the video card.
If it's onboard ( On the motherboard) then I'd suggest clearing the cmos by shorting the correct jumper.
It's usually the one closest to the battery on the motherboard.
If you have a separate video card then I'd suggest removing the card from the motherboard and then resetting it back into the computer.
You might also want to do the same thing with the memory modules.
Let me know what happens.
Posted on Jun 19, 2009
    Top Expert:
  • Computers & ... Master
  • 81,423 Answers
Your monitor I assume is a LCD? if so then the problem may be the special light in the monitor that "backlights" the screen is burned out, if u look through the vents at the back of the monitor u will see a super bright light, u will only see a small portion of the large Neon backlight bulb as it has a shield over most of it. The bulbs can be replaced but it is usually cheaper to replace the monitor. Go to the link for how the LCD monitor works
http://www.howstuffworks.com/monitor.htm
Posted on Jun 18, 2009
  • 13,433 Answers
The computer is not starting up, theres a hardware problem, It would be best to take the computer to a professional who can test the parts and fix the problem.
Just to clarify, is the monitor, mouse, keyboard and modem all not working?
When you start the computer, does anything at all appear on-screen? If not, can I just get you to double check all the connections to your computer are connected securely - especially the monitor.
If nothing appears on-screen, is you monitor's light turned on, and what colour is it?
Please also provide the following information:
  • Monitor make and model
  • Computer's make and model
  • Which operating system you use (Windows XP, Vista, etc)?
  • Was everything working before or is this a new computer which you have just setup?
  • Do you recall doing anything recently that may have caused this to happen?
This information will allow me to assist further. I look forward to your reply.
Best regards
nLinked
  • 2 more comments
  • Anonymous Jun 18, 2009
    I'm sure we can try to identify what the cause of the problem is. I'm still a little confused on exactly what does and does not work.
    I understand you have everything connected to the computer. I still need to know the following and would be grateful if you could answer the following questions:
  • Any error messages that appear on the screen?
  • Does anything at all appear on the screen when you turn the computer on?
  • Regards
    nLinked
    Thanks for your reply but I am still missing the following information, please provide:
  • What colour is the monitor light when you turn the computer on?
  • Regards
    nLinked
    1. Connect everything to the faulty computer
    2. Turn on the monitor
    3. Turn on the faulty computer
    4. What appears on the screen?
    There are two possibilities.
    Your computer's display adapter may be failing and needs replacing.
    Or your computers BIOS needs to be reset. This will require opening up the computer case, removing a tiny switch and placing it back on.
    If you're comfortable with doing this (at your own risk), let me know and I'll give instruction. I don't think the computer is dead, I'm sure it can be repaired at a computer repair shop. Problems like this are very common and easily fixed.
    If you're not comfortable doing the above, it is definately better to get it checked out at repair shop.
    Best regards
    nLinked
    Computer powers on but monitor, keyboard and mouse are not working
    Once the monitor shows "no input", indeed the mouse and keyboard are pretty useless, even if the are working, as you cannot see they are working. If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
    Feb 17, 2013 | Compaq Computers & Internet
    Themouse does not show
    A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
    Jun 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
    Got a dc7600, need to add 2 more monitors, as video cards in my other computers will not fit (too large for slot)..if i can , i need a video card with two slots to attach both monitors or get 2 video...
    Which part of the video-cards are "too large" -- the electronic circuitry, or just the "spine"?
    If just the "spine" is too tall, then unscrew the spine from the card, and attach a shorter spine.
    Or, if you are "brave", then run "*****" -- don't attach any "spine" to the video-card.
    Just connect the VGA/DVI cable from the monitor directly to the video-card.
    Aug 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
    Mouse pad skroll does not work
    well first check weather the scroll lock key is enabled on the keyboard. if it is so just disable it.
    Jan 05, 2010 | Computers & Internet
    Cannot detect LaCie mini hub HD.
    Try a new power supply. $19.99 at Lacie. It worked for me.
    Dec 20, 2009 | LaCie Computers & Internet
    My mouse will randomly disconnect and reconnect to the computer along with freezing, how can I fix this? I've tried uninstalling it and reinstalling it and it hasn't worked
    check the wire of your mouse by testing of multi tester..range in resistance.. then if theres continuity check the parts inside themouse, maybe the gear did not work properly.. jhuntech17
    Oct 26, 2009 | Dell U0636 Mouse
    Concerting TV to PC
    to my understanding,LCD can only be connected as monitor ,not to become a computer itself.if ever it can be use as one, you'll need all the basic of the computer accessories.wireless modem can be use as long as there is a slot for or the unit is compatible for a wireless connection.check first if there is a socket for keyboards and everything before buying.since it can be connected only by vga cable, i assume that it is for monitor use only,unless you want to use two monitors at the same time.
    May 14, 2009 | Televison & Video
    Hp Laptop problem
    conect a external monitor to see if there is any image or if it is the same maybe the memory or prosesor damage
    Dec 30, 2007 | Computers & Internet
    Problem installing optical mouse
    Check the logitech website for the exact model of the mouse. This page has all the mice, http://www.logitech.com/index.cfm/398/&cl=us,en?prodcrid=398
    Pick the one that looks like yours, and you can download the driver.
    Dec 29, 2007 | Computers & Internet
    Computers & Internet Logo
    83 people viewed this question
    Alun Cox
    David Payne
    David Payne
