Question about Intermatic Timer T-101 Indoor 120-Volt 40-Amp 1 Pole Timer
Intermatic T 101 24 Hour Dial Tine Switch Does Not Turn On
The Switch controls my pool sweep operation and has been in place since 1995. It is properly protected and sealed, and is in good condition. 2 days ago the ON tripper began failing to turn on the sweep although the OFF tripper continues to work normally. The clock dial and timing mechanism works properly and the clock keeps time accurately. I replaced the ON tripper but the pump still does not turn on. Using the On-Off Lever manually, it moves easily and smoothly from Off to ON and Off without any undue resistance.
I suspect the On-Off lever may be worn and no longer makes solid contact with the ON tripper, but I can't see it tell for sure. So, my questions are:
1. Is a worn lever contact the probable issue or coulsd there be another problem?
2. If a worn lever is the likely issue, can the time pointer and time dial be removed to provide access to the top of the manual lever?
3. If so and the lever is worn, can the lever be replaced?
4. If 2 & 3 are possible, does it make sense to replace the lever or should the entire switch be replaced?
Any advice will be appreciated and thanks in advance for the help.
Bob
    President:
  • 1,865 Answers
Its 10 years old, replace the whole timer switch
Posted on Jun 18, 2009
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
I have an Intermatic 4 function Air Switch with Timer RC2343PT for my pool and spa blower switch. The timer no longer turns off at night. I have to manually turn the breaker off each night and turn it on...
You might need new trippers?
Problem is not fully clear.
Can't tell what is new, and what is not working. Add a comment.
You have a new timer with same problem as old timer.
And you have a new control box and switch.
At your new house.
You have RC2343PT air switch, likely with PB913N84 24-hour timer module with manual override knob.
http://waterheatertimer.org/images/Intermatic RC2343PT.jpg
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/RC2403RT.ashx
The RC2343PT air switch operates a pool-n-spa blower switch.
Pool and spa blower successfully turns on-and-off with circuit breaker.
Did you install a new PB913N84 timer module?
Are both ON-and-OFF trippers present? Are the 107TN222 and 107TN221 on-off trippers worn down and need replacement?
Does the timer dial rotate and keep good time?
What happens when you manually rotate the timer dial clockwise two rotations? Does the blower turn on-and-off?
Have you checked wiring terminals for signs of loose or burned connections?
Add a comment with more information for possible additional help.
Aug 30, 2011 | Solar Intermatic Rc2343pt 4 Function...
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a T104 timer that runs my pool pump. I also have a switch that lets me turn on the pump from my house. The switch is wired to the timer. I switched out the T104 with the same and I think I messed up...
The instructions are available from Intermatic if you click on the below link.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
240 volts will have two 120 volt lines and a ground(green or bare) or neutral (white) wire.
If your system is 240 volts the Red and Black wires are hot should be individually connected, one to terminal 1 and the second color to terminal 3. The load or pump in your case should be connected to terminal 2 and 4. If you want to wire a switch to the load you need to decide on how you want the switch act, 1) as an auxiliary on 2) as an emergency off. If you want an auxiliary on for the pump, you need a DPDT (Double Pole Double Throw) 40amp switch (what should be in the house). Run the appreciate gage of wire (AWG 8 for 40A) from terminal 1 to one pole of the switch and a wire from terminal 3 to the second pole of your switch. Next run wires from the switch contacts from the two remaining switch terminals to terminals 2 and 4 on the timer matching the Red side on the switch to and Red on the timer and Black side on the switch to Black on the timer. The timer will control the function of the pump, and the switch will turn the pump on when the timer is off. If you only have two hot wires coming from the house attach them to terminal 2 and 4. If you want an emergency stop you need to wire a second DPDT 40amp switch and disconnect the load wires from terminal 2 and 4 and connect each one to the opposite poles of the switch. Using the correct gage of wire you need to connect a red and black wire to the two separate terminals of the switch. When the switch is off the pump will not work but the timer will keep the current time. The color of wires may not be the same in that situation you will need a multi meter to identify the wires.
I need a little more information on the pool sweep timer. Are you using the same timer or just the power? Is the power 120 or 240 volts? When do you want the pool sweep to be active?
Mar 21, 2011 | Intermatic Timer Pool/Spa 125 Amps Control...
My pumps won't go off when the timer says it should. It just keeps running. I have to throw the breaker to turn off the pumps.
Does the manual override turn Load ON-OFF? If manual override is broken or doesn't operate, it may be time to buy new timer mechanism and snap into existing box.
http://www.amazon.com/dp/240Volt-20
http://www.grainger.com/Grainger/INTERMATIC-24-125V-Hour-Dial-Timer
Do timer dials rotate as time passes? Do dials keep proper time? If not, you need new clock motor. Grainger sells clock motors and trippers:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Are the tripper pins still attached to the dial? If tripper pins are worn down, they need replacement.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic PF1202T - Pool-Spa Freeze...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
Intermatic Timer T-101 Indoor 120-Volt 40-Amp 1 Pole Timer Logo
205 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
