When i hook up the power wires and ground, the reciever lights flash, nothing else
SOURCE: New KDC-135 has Power but Faceplate won't light up
you shold always twist the end of the wiring together and tape them never use connectors, remove the connectors and twist the wires driectly to each other and tape them wiht electrical tape, the connectors almost always can not deliver the proper voltage..
Did you make sure you have the yellow to a constant connect wire and the red to a turn on?if not this can cause the radio not to work......
you can test wich is wich by turning the key off and putting the yellow to the one you think it is and red to the one you think it is, if you have have it right you will hear the CD player make a click run sound...... if not you will not hear any thing.
SOURCE: radio wont come on
There should be a reset button on the unit. That would probably be the first thing I would look at.
SOURCE: im trying to install a kenwood kdc 205 and i just
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
SOURCE: I have a kenwood KDC-S3007 CD reciever and it has
any local car audio store that carries kenwood, or maybe best buy should be able to sell you a wire harness. if not, try pacparts.com.
SOURCE: I have a kenwood kdc-3165
black is ground, yellow is constant and red is switched or ignition.
