Logik tv can't read exfat usb
In reading the instructions for a B&H DV200HD I see that under system requirements only Windows operating systems are listed but I have a Macbook pro. Will the software work with a Mac product?
If it's a USB device it should work with any system, i have found that Macs like to format under their own system and i have had cases where they wn't read a windows config HD (but they normally do)
If it's USB then they should work, current mode is called EXFAT and most Macs can support this.
Apr 22, 2017 | The Computers & Internet
Why can't it play video on sumsung tv? Have tried it on two different Samsung and both say no contend, yet if you plug it into mac movies is there. Can you help? Model number wdbaar3200abk-00
Samsung TVs recognizes FAT, exFat and NTFS file systems while a USB storage device that works on a Mac is probably formatted with Mac OS Extended (Journaled). Copy the contents of the device onto your computer and then reformat the device using exFat. After the format is done, copy the contents back onto the device and your Samsung should now recognise your videos. This is a list of the media files Samsung can read.
http://www.samsung.com/ca/support/skp/faq/1057345
Jan 22, 2017 | Samsung Computers & Internet
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
They can not open
you need to format for exfat so windows and mac can read, if its formatted as fat 32 a mac cannot read, which type of computer are you running and have you tried it in two different computers?
Mar 26, 2014 | Kingston DataTraveler 310 DT310/256GB...
Alienware area 51 card reader not recognizing 64gb exfat sd card
I would check you have all the latest updates for your Vista installation as I know for some versions of Windows extra updates are necessary for exfat support.
Does the SD card read; is it accessible; in other devices?
Mar 19, 2014 | Alienware PC Systems Alienware Area-51®...
Any new type of flash memory my PC read it but can't access it
Is the new flash memory greater than 2 GB? You will need to install the exfat parch for windows xp.
Feb 19, 2014 | Computers & Internet
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
When I connect my Iomega Ego Portable Hard Drive to my Iomega ScreenPlay TV link Director Edition, I can see the files, but I can't play anyone of them: the ScreenPlay TV waits for minutes (trying to...
try to change the format of the portable hard drive, i believe you have it under ExFat, and a usb is Fat32 these options are under any windows platform, connect your device, right click and select FORMAT, here change it from ExFat to either Fat32 or NTFS, the difference between the 2 is simple, Fat32 is more compatible to devices, like car stereos, tvs, etc, but it has a limit of uploading a single file up to 3gb were NTFS doesn't have a limit but not many devices support it. Formatting your drive to another one requieres all media to be deleted, and when your formatting, never forget to select "QUICK FORMAT"
hope this helps!!
Aug 18, 2017 | Iomega ScreenPlay TV Link Ultra-Compact...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
