Question about Garden
Turn key and it want start starter want engaged
  • Dwain Pippen May 11, 2010
    What does it do when you say it won't start? Does it make any noise at all like clicking or whirring or anything?
    Sergeant:
  • 353 Answers
May be loose connection at key switch
(wiggle plug while turning key)
start solenoid may be bad
Posted on Jun 20, 2009
Intermittently there is a problem starting the car. The key turns on all the electrics but when turned further it does not engage the starter.
Check your ignition switch electrical side
Check the relay
Or the starter motor itself must be playing up
Aug 03, 2016 | Cars & Trucks
2005 GMC Envoy XL. Will not engage starter. Like something electrical. Turn key and nothing. Worked fine until now.
Could be the neutral safety switch if it won't crank in neutral or park, could also be the starter has failed.
Feb 22, 2015 | 2005 GMC Envoy Xl
Starter wont engage
either the starter is not kicking out its gear to meet the flywheel or the flywheel has missing teeth. either way the next step is to remove the starter so it can be tested outside of the vehicle and the flywheel can be looked at through the hole where the starter sat.
Mar 05, 2013 | 1987 Ford Ranger
2000 Isuzu Rodeo intermittent starter spins no start
This is very common bad starter, replace the starter and the problem will be solved, some of these isuzu starter are a pain to replace, good day
Dec 25, 2012 | 2000 Isuzu Rodeo
Hi, have a toyota avalon, tried starting the car , it won't start, but then the starter engaged and won't turn off evenwithout the key, disconnected the battery and it stopped , when the batte
It sounds like you have a bad actuator. This is attached to the starter and has a solonoid that pushes the starter motor gears into the engine gear. If the solonoid is faulty this may happen. Also check alignment of the same.
Mar 18, 2012 | 1999 Toyota Avalon
2004 ion won't start. Lights work. When I turn key don't get series of clicks, get one snap.
That symptom usually means the solenoid on the starter is bad and no longer is completing the circuit to engage the starter. A new starter will likely solve that issue. A series of rapid clicks would indicate a week battery. You can try repeatedly turning the key to the start position rapidly, sometimes the starter wil start working. You can also try tapping the starter while somebody holds the key in the start position, if the starter engages place it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 16, 2011 | Saturn Ion Cars & Trucks
Key start turns and makes a whining "I sort of want to start" noise but does not engage the engine. Previously the key start was sort of touchy and the key had to in just the right position to engage the...
If it is whining, the starter motor is turning. You possibly may have a broken starter drive. This is the little gear on the starter shaft. It's not too expensive and relatively easy to replace.
Apr 19, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Ignition on but starter won't engage. Had new key
sounds like you need to relace the starter
Jan 05, 2010 | 1997 Chevrolet Lumina
Freelander unable to start at turn of key,
Does the starting solenoid engages? This is would sound like a deep clunk on your starter. When the solenoid engages it close the contact that energize the starter motor, but a worn contact on the solenoid would result in it engaging but not having enough current to turn the engine resulting in a clunking noise when you try to start.
The starter solenoid gets its 12 volt from a relay. This is referred to as the starter relay. If you try to crank, and you hear only a click but the starter do not turn, then the contacts on the relay maybe worn.
To sum it up, if you hear a loud clunk when it dont crank, its the starter solenoid. If you hear just a click but no crank, it could be the starter relay.
Aug 06, 2009 | 2002 Land Rover Freelander
1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Dec 23, 2008 | 1998 Buick LeSabre
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
