Question about Husqvarna Garden
Which engine oil should I use in husqvarna crt-51
2 Suggested Answers
SOURCE: Why would the chain not be oiling properly on my husqvarna 51?
Put oil in the reservoir.
Posted on Apr 21, 2012
Husqvarna crt 51 rear tine tiller serial number location
It was on a sticker down on the frame but is very prone to falling off, the machine did not change too much so parts lists are much the same between years if it is parts you are after.
May 24, 2017 | Husqvarna Garden
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
How to adjust oil flow to bar on husqvarna 51 saw
The 51 does not have an adjustable oil pump.
Feb 16, 2014 | Husqvarna Chain Saw 20" Bar
Chain oil leakage
To help you more please give us the model of your Husqvarna machine.
Feb 09, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
THERE IS NO SCREW TO ADJUST BAR OIL ON MY 51 HUSQVARNA IT JUST COMES OUT WAY TO MUCH THERE IS NO SCREW TO ADJUST SERIAL NUMBER OF MY SAW IS 425-1275
try this click here .. been awhile since i worked on one. it is nice to have lots of oil, but should be same as a tank of gas .. jay the pool pump repair guy florida
Feb 03, 2012 | Husqvarna Garden
I am using a borrowed Husqvarna model 51 chainsaw (aprrox 18") and having a problem with the chain seizing up. It worked fine for 30 minutes or more, and then the chain suddenly had much more...
Sounds like the bar is to tight.There should be a cover and 2 studs,loosen the nuts and then look for an adjusting screw at the back of the bar and back it off.The chain should have about 1/8 slack when pulled from the bottom of the bar.A tight chain will heat the bar and turn it blue close to the chain guide.A new bar will be required. Thank you for using FixYa .
May 11, 2011 | Husqvarna Chain Saw Models 51, 55
ENGINE OIL CHANGE QTY
Your owner's manual states: 51 Ounces W/Filter and 35 Ounces of Oil Without Filter. This info can be found under specifications.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_532430577.pdf
Mar 23, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Jul 01, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
