Question about Car Audio & Video
Eonon radioHi.I have a new D5156e and the problem I have is that the unit randomly switches itself on and off.When off I cant switch back on manually.It is fitted to a 2012 Vauxhall Zafira using Cd30
Loss of power and radio switches itself off and on
consaka
  • 661 Answers
SOURCE: have the cd30 mp3 and
Sorry mate but that file does not exist for download on the net. you will have to go back to the manufacturer and request it.
Posted on Jun 22, 2010
  • 4848 Answers
SOURCE: I had a new battery
SAFE means wrong codes have been entered previously
To reset, leave SWITCHED ON...UNDISTURBED for an hour or more
Make sure you have the correct code.
If not sure post the 14 character Serial Number beginning with GM0400******** found stamped in the metal casing
Posted on Feb 02, 2011
pctech1
  • 1940 Answers
SOURCE: hi there.i have pioneer avh-p5000dvd.First
Using a multi-meter, check all leads and connectors are correctly connected, and are receiving the correct voltage from the vehicle, and through past the inline fuses:
  • Yellow - Constant +12 VOlts (check inline fuse as well)
  • Red - Switched +12 Volts (check inline fuse as well)
  • Orange/White - Lighting Switch Terminal (check inline fuse as well)
  • Black - Chassis Ground
  • Blue/White - System Amp Remote
  • Light Green - Parking Brake Safety Lead
  • White & White/Black - Front Left Speaker
  • Gray & Gray/Black - Front Right Speaker
  • Green & Green/Black - Rear Left Speaker or Subwoofer (4-ohm)
  • Violet & Violet/Black - Rear Right Speaker or Subwoofer (4-ohm)
Check the Vehicle Radio Fuse, the fuse on the back of the Pioneer unit, and the inline fuses.
Noise and other factors may be causing the built-in microprocessor to operate incorrectly, press the RESET button on the unit and try again.
Resetting the microprocessor
Pressing RESET lets you reset the microprocessor to its initial settings without changing the bookmark information.
The microprocessor must be reset under the following conditions:
• Prior to using this unit for the first time after installation
• If the unit fails to operate properly
• When strange or incorrect messages appear on the display
  1. Turn the ignition switch OFF.
  2. Remove the front panel.
  3. Press RESET with a pen tip or other pointed instrument.
After completing connections or when you want to erase all memorized settings or return the unit to its initial (factory) settings, Switch your engine ON or set the ignition switch to ACC ON before pressing RESET.
If any of the previously mentioned advice doesn't work for you, you may have a faulty device.
Posted on Mar 19, 2011
  • 4848 Answers
SOURCE: fitted a cd30 mp3 unit
It is showing SAFE because wrong codes have been entered previously.
To reset , leave SWITCHED ON..UNDISTURBED for as long as it takes to automatically reset itself
This can take an hour or more
Posted on Apr 05, 2011
Wolfman304
  • 720 Answers
SOURCE: I bought a vauhall zafira
Whenever you have made incorrect attempts to enter your code, the radio starts a timer a delay before you can make further attempts - the longest waiting period is 24hrs.
- Turn off radio
- Press and hold the AS button and turn the radio ON, until display reads CODE.
- Wait and the display will change to 4 dashes
- Using the 1st Preset button, continuously press the preset until you have entered the desired 1st digit of your code.
- Using the 2nd Preset button, continuously press the preset until you have entered the desired 2nd digit of your code.
- Using the 3rd Preset button, continuously press the preset until you have entered the desired 3rd digit of your code.
- Using the 4th Preset button, continuously press the preset until you have entered the desired 4th digit of your code.
- Now press and hold the AS button again until you hear a beep (the beep indicates the 4-digit code has been saved).
If after the code is saved, the radio still does not activate, then remove the radio fuse (inside fuse box) for a few seconds then replace. Wait 24hrs before attempting to enter the code once again.
If the radio still does not activate, then I suspect you may have been given the incorrect code. In this instance, I recommend you contact Vauxhall once again for assistance.
Cheers,
"If this has helped you, please be kind enough to write a testimonial or rate with thumbs up"
Posted on Jul 10, 2011
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
Randomly switching off and coming back on by itself.
power supply board may be failing or the power button may be sticking. If it is a Samsung, it is the power supply.
Nov 17, 2009 | Televison & Video
Computer shuts itself off randomly!
Could possibly be a bad capacitor on the board. Or could be overheating. Clean out the inside of the case with some compressed air and double check all fans are operating.
Oct 20, 2009 | ASUS A7V400-MX Motherboard
Eonon 1025e screen mechanism broken. Need to replace two of the gears but cant find spares anywhere
Hi I have the same problem.E1025 unit has broken gears to make unit come out so just removed broken gears and manually pull out.Screen would fold up and down still until today .Now the other plastic gears have broken.I have tried to contact eonon to buy spares but dont wont to know about it.Now looking at old remote cars,video recorders etc to find something that will fit.No luck yet will let you know if i do. Eonon ****
Oct 02, 2009 | Car Audio & Video
My keypad is crazy,presses keys itself,all func. hav changed.
ok!!! your phone needs some clean coz the your keypad is randomly cant press will right!!!! then there is something on the switch of your phone i think you press it hard thats why the switch is not functioning well!!! that is tjust the problem of your cellphone ok!!!!
May 20, 2009 | Nokia N72 Cellular Phone
Eonon 4inc incar dvd player lights come on but screen stay blank
check to see if the brake wire on the head unit is pos or neg once you find that out go to auto zone and buy a toggle switch and run the pos or neg to one end and the brake wire from the head unit to the other and the sequence is 2 seconds on to off reffer to your manual to be for sure
Mar 02, 2009 | Car Audio & Video
How do i bypass the parking brake switch on my eonon
all u gotta do it the light pink wire that has brake label on it, connect it to the casing of the dvd itself, thats what I did, works like a charm, u might gonna have to run it through an opening of the casing and twist it around itself to hold in place
Sep 24, 2008 | Alpine IVA-D310 Car DVD Player
Eonon faults
You have only conected the live feed, that will cause the light to come on but not switch on. You must conect the switched live feed as well, then it will turn on.
Good luck
Aug 07, 2008 | Car Audio & Video
Source Keeps Switching To Standbye
There's nothing in the wiring that could cause this problem; sounds like a fault in the faceplate. I would say the unit needs to be serviced.
Mar 13, 2007 | Kenwood KVT-715DVD Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
