"SMB Logon Error: 031/522" - Office Equipment & Supplies
SMB
check if there's an error code in the completed queue.
Also it would be helpful to know what kind of operating system is on your computer since MAC and Windows 8 are not that easy through SMB.
Check if you shared the file on your computer to full acces rights
May 28, 2013 | Konica Minolta Bizhub C454 Color Copier
Failed to send via SMB
What model copier? What error code? What OS?
Jan 17, 2013 | Kyocera Office Equipment & Supplies
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Nov 08, 2010 | Toshiba Office Equipment & Supplies
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Mar 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Oct 30, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Smb scanning
check the firewall settings. ie exemptions
Oct 29, 2008 | Canon imageRUNNER 1023iF Black and White...
SMB Scanning
I had the same issue and fixed it by adding the group "Everyone" to the shared folder permissions (where I was sending my scans) and assigning the "Everyone" group rights to "change" and "read".
Mar 30, 2007 | Konica Minolta bizhub C250 All-In-One...
22 people viewed this question
k24674
jasbo
jasbo
