Question about Whirlpool WGT3300SQ Dryer
Washer dryer combo wgt3300sq1 cant figure out why it wobbles.
During spin cycle the machine goes absolutely crazy. i tried looking for any kind of shipping bolts. but i dont even know where to look. everything is level. any suggestions?
catriver
  • 878 Answers
SOURCE: Whirlpool Duet Washer
dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. Catriver..post back.
Posted on Apr 02, 2007
dididsaythat
  • 291 Answers
SOURCE: Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Posted on Aug 29, 2007
docjohn174
  • 943 Answers
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Posted on Sep 11, 2008
SOURCE: dryer takes 3-4 cycles to dry clothes
Check if the outdoor vent is clogged by lint. Also, check the tube going from the dryer to the wall. If the air outlet is blocked, the dryer takes very long. I had the same problem.
Posted on Jan 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 18, 2009
My machine is extremely loud when it spins. what do I need to do
I would guess you need to level it. Most washers and dryers have some sort of self leveling in their feet but some do not. Attempt to lift the rear of the machine up two to four inches and then set it back down. Check to see if it wobbles. If is still wobbles you may need to adjust the foot using an open ended wrench.
Oct 18, 2012 | Amana Tandem 7300 Washer and Dryer Stack...
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Top loading washing machine tub wobbles a lot during spin cycle.
The top lifts off, then you can see the area around the drum and tank. There are springs and dampers that hold the frame and the drum steady. Check to see if they are broken or loose.
Feb 26, 2018 | Maytag Washing Machines
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer will not go through spin cycle
it sounds like it could be the lid switch malfunctioning. the part should look something like this. d668319.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool WGT3300SQ Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
