Question about Garden
Get rid of centipedes - Garden
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
How do I get rid of these pests?
Sulekha.com has professional exterminator for Pest control Services. Sulekha - where you can find list of best Pest treatment companies for termite, bed bugs, rodent/rat/mouse control, Honeybee & Cockroach protection services by spraying organic, non chemical methods and Fumigation treatment.
Benefits of searching in Sulekha:
1) There are Huge number of Pest Control Companies
2) Real customer reviews
3) You can Compare them with ratings & reviews
4) It suits to your budget
5) Verified Business Peoples
Get best pest inspection at your doorsteps with Sulekha com For all your Local Needs Property Details
Tollfree: 1800 420 1212
Mar 14, 2016 | Home
How do u get rid of gnats when u don't know where they r coming from
6 Ways to Instantly Get Rid of Gnats at Home - Organic Lesson
www.organiclesson.com/6-ways-to-instantly-get-rid-of-gnats-at-home/
Preventing Gnats in the Future. Clean Up Dirty Dishes. Make sure there aren't any dirty dishes lying around in the sink. Cover & Get Rid of Trash bags. Make sure your trash cans are well covered. Get Rid of Damp areas. Change pot soil.
Oct 19, 2015 | Gemplers Mosquito & Gnat Barrier -- 1/2...
How do I gwt rid of gnats in the house ?
Hello, Here is website for 6 remedies on how to get rid of gnats in the house. How to Use Home Remedies to Get Rid of Gnats
Oct 07, 2014 | Windex Multi Task with Vinegar, 32 oz....
What does a centipede look like?
A centipede looks pretty intemidating in my opinion. Check out the photo below:
Hope that helps!
Jul 05, 2014 | Home
My husband used round-up on our lawn thinking it would only kill weeds. The whole lawn has big yellowed dead patches. It's been raining for two weeks and everyone's lawns are lush and green :( Is...
A lot depends on what part of the country you are in and if you have cool season or warm season turf. Cool seasons are fescue, bluegrass, perennial rye, etc. Warm seasons are bermuda, zoysia, centipede, St. Augustine, just to name a few.
If its cool season turf, you could heavily aerify, fertilize, and re-seed right now. Hope for rain through the summer, or use irrigation of you have it. For my area, early fall is the best time for seeding cool season grasses. If it was only Roundup you should have no lingering effects from its application.
If its warm season turf, it may not actually be completely dead, especially if the application wasn't done properly. Your lawn may just be sick. It actually can take a lot of chemicals to permanently damage most warm season turf. If thats what you have, some water and fertilzer may improve the appearance. Beyond that, sprigging or sodding may be your only option, since not many warm seasons are available by seed.
Time will help both situations, especially the latter.
May 10, 2011 | Garden
The game works but it is all fuzzy and looks like a rainbow blur of colors I can still play it but barely. I dont see any big scratches. it is my favorite game and I can not find another copy anywhere
clean ur laser lens with alcohol and a q-tip inside disc tray dreamcast and use laser lens cleaner disc also,,clean and wipe game with alcohol and or high def wipe dry cloth in circles should help u
Jan 21, 2011 | Hasbro Interactive Centipede for Dreamcast
I am unable to save game to memory card
firend u need to install memory card which can be done by configuration and select a location to save.
Jan 21, 2009 | Midway Home Entertainment Centipede for...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
