Question about Krups Aroma Control 229 Coffee Maker
Starting product Push 0 button but nothing happens can't make coffee
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
When I push the "brew" button, it makes noise like
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 27, 2011 | Keurig Platinum B70 Coffee Maker
It says 'ventilate' and nothing works. I have tried to turn it off and back on but it doesn't work.
Hi
Like the Royal Pro machine and Royal Coffee, there is a water button on the Comfort that you need to press to run water. If when you press it and nothing happens you have a stuck solenoid, probably from scale build up. See what happens when you push the button with the drop of water or it may have many drops depending.
Dec 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
Water won't flow out of espresso machine
Did you check to see if the heating element is not open?
Sep 09, 2017 | Krups XP 4050 Espresso Machine
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Krups Aroma Control 229 Coffee Maker Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
