Want to clear memory of Digidoor 2 receiver - Audio Players & Recorders
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
Why does myd digidoor ii opens fully but does not close ...just moves front then back again
The child safety interlock is not set right. The transmitter and receiver are placed at the bottom of each side of the door. If the transmitter/receiver are not aligned correctly, the door will not close.
Line up the transmitter till the light on the receiver lights up.
Aug 22, 2014 | Building Materials
How do i empty bluetooth memory on a AVH-P2400BT
I'm having the same problem how do u clear blue tooth memory the erase button isn't lit up and can't click it
Nov 21, 2012 | Pioneer AVH-P2400BT - Bluetooth Enabled...
How do I clear the fax memory of the MFC 7860DW
Hello there, you can try the following: 1. On the Touchscreen press the MENU.
2. Press FAX.
3. Press SETUP RECEIVE.
4. Press the UP OR DOWN ARROW to choose MEMORY RECEIVE.
5. Press FAX STORAGE.
Then if you want to clear fax memory find clear or reset memory if you are not able to see it then turn the fax storage off then restart the printer then check.
Then again turn on the fax storage if you want to store fax in memory.
Thank you.
Sep 01, 2011 | Office Equipment & Supplies
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Out of Memory
I called Brother. Go to "Menu, then "8" then "2" Follow the screen to clear the stored faxes from your memory.
Aug 01, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
15 people viewed this question
 Grubhead
Grubhead
