Question about Alpine Type-R SPR-69LP Coaxial Car Speaker
Speakers quit my speakers cut out..I have the "r" model speakers? I have rca cable from my deck to my amp (alpine) and then speaker wire from the amp to the speakers and they cut out when I turn them up! Any suggestions? Thanks
    Problem Solver:
  • 4 Answers
Check ur wires and make sure ur ground is good.be sure u have the neg. and pos. rite all threw the car
Posted on Jun 19, 2009
I can't seem to find the remote wire for the RCA leads that go to my amp
  • The remote wire connects the head unit/deck and runs to the amp. You have to supply this wire. It does not have to be to thick of gauge like the power and ground wire.
  • The RCA connects from the deck to the amp if your deck has them. All the newer decks do but not all decks have a spot for RCA cables.
  • The two are different. The RCA cables are what sends the audio signal to the amp for the speakers. The remote wire sends a power feed signal that turns the amp on when the deck is turned on. It's basically the on/off "switch" to the amp activated by the deck being turned on/off.
  • Thanks for using FixYa.
Regards, Tony
Jun 18, 2011 | Car Audio & Video
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/Green
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Alpine Car Audio & Video
I just got the MRP-F300 amp installed today and the rear-left speaker completely stopped working shortly after the installed. There is no cracking, hissing, or any noise whatsoever coming from that...
not usualy if you were running them before without the amp the speaker could have still easily blown. with just the deck running the speakers you can clip the sound and damage the coils hook up and amp then you force the power through an already damaged speaker finishing it off try another speaker. or if it was bought used amp may be no good the previous owner probably noticed it cutting in and out and sold it before it fried. or the deck is old and yes it is a possibility the radio went bad. if you used cheap rca cables yes it could be bad as well.
Apr 08, 2010 | Alpine MRP-F300 Car Audio Amplifier
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
Alpine stereo car deck installed in place of factory Bose with
What you have been told is correct, these proprietary systems are great for the manufacturer, but when they start to have issues (and they will) they leave you 2 options: pay through the nose to stay original or replace the amps with new ones....the upside of this is aftermarket amps are soooo mugh better than stock that it is lauhgable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | Car Audio & Video
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine Type-R SPR-69LP Coaxial Car Speaker Logo
78 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
