Question about Acer Aspire One PC Notebook
Aspire One won't turn on because it is out of power.
I tried to plug it in and it could not find the charge. Occasionally the battery light would blink orange. If you were to press the power button, the light would blink faster. I can see that only either the AC adapter is broken or the computer is being weird. Please note, I had just gotten it back from the repair shop in Texas, I don't want to ship it again.
  • mikevicki_an Jun 18, 2009
    I figure out that the problem was the AC Adapter so I'm going to get a new one. I found out at www.Acer.com.
    Scholar:
  • 119 Answers
I dont have that much experience with Acers, but one thing I do know is that when laptop batteries are really drained [especially if that happens when applications were running] the system goes into this unconscious state and only power up once the system has enough battery power. However, that doesnt imply that the problem is always battery related. sometimes harddisks 'lock' and refuse to come out of that state until you do something like hold down the power button for like 10 seconds' or even manually remove the CMOS battery located on the motherboard
Posted on Jun 18, 2009
Acer aspire 4830t-6841 power button blinks 5 times won’t turn on. Happened during latest windows 10 update.
Buy a new powerbrick, it is probably the battery not charging.
If i let my acer run without powerbrick and its battery is empty, i get 5 flashing lights.
Jan 25, 2018 | Acer Computers & Internet
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Acer aspire 5111 won't turn on
Common problem is HDD won't come up to speed and needs replacement. Can try unplugging and removing battery, then re-install and try to start. If that fails, need to install new HDD. Hope you have backed-up everything.
Feb 06, 2018 | Computers & Internet
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One  PC Notebook Logo
248 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
