Question about PfaFF Creative 7570
I need to access the tension plates on my Pfaff creative 7570
    Problem Solver:
  • 5 Answers
To access the tension disks, remove the top of the machine as follows: 1. With the carrying handle raised, remove the cover (the piece that has all the stitches pictured). 2. Unscrew 2 screws completely; one is in the depression where the thread spool goes and the other is right behind the bobbin winder. 3. pull straight up. You may have to jiggle it a bit. 4. you should be able to see the tension disks from here.
Posted on Apr 24, 2014
  • 8 Answers
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
  • 8 Answers
SOURCE: Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Posted on May 20, 2008
  • 323 Answers
SOURCE: Jamed Pfaff CD 7570:
Your machine probably has a thread lock which is a piece of thread caught in the hook. If this is the problem then here is the solution.
Grasp the hand wheel and turn it back and forth,increasing the amount of force used each time. It should break free after about 4-6 tries
sewman7
Posted on May 08, 2009
  • 5 Answers
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Posted on Dec 15, 2009
sevmanal
SOURCE: where can i get repair manual for pfaff 7570
I have a Pfaff Creative 7550, and i have problem. When pressing the foot pedal starts stitching for 3 seconds and stops. I have checked the foot pedal and cleaned it and it is fine. However if i help a bit with the hand wheel having the foot pressing the pedal it starts working for other 3 seconds and stops again. I can go on and on with this... What can be the cause of it?
Posted on Jan 17, 2010
Top sewing foot will not go all the way down
Pfaff creative 7570 Manual
https://www.manualowl.com/p/Pfaff/creative-7570/Manual/184474
Manuals and user guide free PDF downloads for Pfaff creative 7570.
Sep 25, 2015 | PfaFF Creative 7570
Foot leaver will not go down properly
See
How do I move the needle from right to left on 7570?
Aug 01, 2015 | PfaFF Creative 7570
Need a user manual for a pfaff 7570 sewing machine
contact pfaff customer service or sewingpartsonline.com
Mar 19, 2012 | PfaFF Creative 7570
I need the single needle throat plate for my Pfaff 7570. Both of my dealers no longer carry or support Pfaff products.
http://www.pfaffmachines.co.uk/contacts/ thats the UK site,, you can enter your machines info into their customer service page, Or the page also has their phone number,, Hope that helps some Good Luck
May 15, 2011 | PfaFF Creative 7570
How to get to the light bulb to change it on a Pfaff creative 7570
Hi, keep searching this site...it is there, look for answer by paintbox, use #25 Torex drive in hole on left side down under handle, loosen screw and pull off end plate to left. You can also clean out lint and stuff from mechanism.
Jan 08, 2011 | PfaFF Creative 7570
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Oct 19, 2009 | PfaFF Creative 7570
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
Aug 10, 2008 | PfaFF Creative 7570
Threading a pfaff creative 7570
Jan 30, 2008 | PfaFF Creative 7570
Sewing Machines Logo
81 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
